for turbo apps why carb style intakes
I been searching and trying to find out why peeps go with the carb style intake over the ls6? Seeing guys running 8.50's with the ls6 like twntrboce he told me if im not planning on spinning my engine over 7k i dont need the carb style intake well i dont know if im planning on spinning my motor that high hope i dont have to . But he is running dayum good and there are others also with the ls6. So is it that guys go with the carb intake just so they dont have to do it again when they go faster? If so that makes sence meaning what will i loose running the carb style vs the ls6. Before you guys ask im running a 370ci motor planning on a pt 91.5 th400 so whats your imput on this go ahead and get the carb stlye or go ls6
Originally Posted by KraZy
I think the advantage of running a carb intake was getting an even amount of air to each cylinder.
Originally Posted by KissMySSo1
i dunno why everyone says theres no power diffrence. mine made a huge diffrence.
i plan on doing the carb intake w/ my setup. from reading the air distribution is argueable b/c the runners are not equal length.
another benefit though is you can run a 90mm TB instead of bottle necking the boost w/ a ls6 throttle body.
Originally Posted by Bird-Of-Prey
This is correct. It's not for power reasons but for safety. The #7 and #8 cylinders are the first to go lean with the LSX design and alot of guys were popping their motors because of it. The carb style has air coming in from the top and gets more evenly distributed. That's the reason I switched.
Originally Posted by SSilverSSurfer
you switched from your FAST to the carb style
Originally Posted by Slowhawk
I'm sold on the Carb intake setup. Made the switch many times,then the cars could be tuned leaner without affecting #7+#8 cylinders.On low HP cars it makes little difference(under 600rwhp) but they start to shine in the 750rwhp+ range.
