Top ring to use for forced induction?
Old 12-08-2006, 04:46 PM
Restricted User
Lawnboy's Avatar
Default Top ring to use for forced induction?
Hi
I am building a 346 LS1 soon.
with Eagle 6.125 H-beams rods , diamond -8.6 pistons and the stock crank.
OK i have The diamond piston ring set,
But i keep on hearing something about a chrome top ring for forced induction, is it better than what comes in the Diamond ring kit?
what brand is it how much , and where can i get them
thanks for the help
Old 12-08-2006, 08:32 PM
Redline-Motorsports's Avatar
I'd you either a set of Hell Fire rings or use a stainless steel top ring. Don't use anything but standard tension rings.
Howard
Old 12-08-2006, 08:33 PM
TT-TECH Veteran
Inspector12's Avatar
Total seal and they are around $400 last time I checked. I don't know what everyone is using, but it is want W2W recomended for me.
Jeff
Old 12-08-2006, 08:53 PM
Restricted User
Lawnboy's Avatar
Hi Howard
thanks for the help,
I think the diamond is a stainless ring, but not 100% certain,
What is hell fire rings , who makes them
is anyone using the diamond rings in there forced induction LS1
Old 12-08-2006, 10:32 PM
Tom@SpeedInc's Avatar
When you order diamond rings, you need to specify "blower." Diamond sells Total Seal Stainless top rings when specified, it costs more then normal.
Course I have a very competitive price on these
However these rings we have noticed have little room for error, when it comes to cylinder wall surface.
Old 12-09-2006, 12:04 AM
Restricted User
Lawnboy's Avatar
how do i know what i got? , they are in a diamond package
Old 12-09-2006, 05:42 AM
EPP
EPP's Avatar
Smile
The part number for the ring package will let us know what you got, and you do indeed want the chrome top ring. Bob
Old 12-09-2006, 06:41 AM
JMBLOWNWS6's Avatar
Hell Fire here
Old 12-09-2006, 08:16 AM
Restricted User
Lawnboy's Avatar
HI bob,
OK i will get the part# off the Diamond ring package,
Why so important the Chrome top Ring? with the forced induction
Are all the other rings the same from package to package?
Would you or Diamond exchange them for the right ones?
what would be the Price differance, are these total seal in a Diamond package?
Old 12-09-2006, 09:23 PM
Restricted User
Lawnboy's Avatar
OK Bob
There are 3 boxes inside the diamond piston ring box.
The Top ring part # is 06103905 Plasma moly steel
The second ring # 07233905 Plasma moly Ductile
The oil rings # 08323905 Low tension
Is this the right ring set ,
Please let me know
Old 12-09-2006, 09:32 PM
NYSS Guy's Avatar
+1 for Hell Fire.
Old 12-09-2006, 09:50 PM
Restricted User
Lawnboy's Avatar
Can you please tell me who Hell fire is , how much they cost and why they are better than the diamond Pro select rings
Old 12-09-2006, 10:33 PM
NYSS Guy's Avatar
To be quite honest, I don't even know how much they are. The guys at LME built my short block, and they highly suggested them. These guys know their stuff. I can tell you that while I've been tuning, I have had a couple of "OH MY GOD....WHAT DID MY AFR JUST HIT?!?!" moments. And the rings are holding just fine.
(don't mind me as I knock on wood!)
Old 12-09-2006, 10:41 PM
GTFORMULA's Avatar
Im not positive but I think speedpro makes Hellfire rings.
Old 12-09-2006, 10:42 PM
onefastss223's Avatar
I searched and the only thing I could find was that HellFire rings were made by Speedpro/Federal Mogul. Couldnt find a place to purchase them though.
Old 12-09-2006, 10:47 PM
Restricted User
Lawnboy's Avatar
OK
But what is the top Chrome ring i am hearing about,
sounds like i can just use the diamond Pro-slect rings i have , but use a diferent Top ring.
Old 12-09-2006, 10:49 PM
Restricted User
Lawnboy's Avatar
what are the Hell fire rings made of?
My Diamond rings are made of Plasma moly steel and the 2nd ring made out of plasma moly Ductile
Old 12-09-2006, 10:51 PM
I'm as lost as you....maybe someone will chime in and help us out. I was plannin on goin with the diamond pro-selects but the HellFire rings may be my substitute.
Old 12-10-2006, 06:10 AM
TT-TECH Veteran
Tal to the ring manufacturers. They were very helpful in explaining all of these questions I had about some of the specific rings etc... The Hell Fire rings will hold up, but I think they wear a little more on the cyclinder wall than some of the other choices from what I remember when I was doing research. And when I say that don't freak out and think that you are only going to get 5000 miles out of the motor it isn't that big of a difference we are talking very small amounts of differences. But if you want to know for yourself give one or a few of the ring manufactures a call and tell them what you want and they will tell you what you should use or give you a few choices depending on your goals and longevity.
Old 12-10-2006, 06:35 PM
7 Second Club
ty_ty13's Avatar
i use tool steel top ring...
Quick Reply: Top ring to use for forced induction?
