Guess HP
Old 12-14-2006, 04:31 PM
1INSANEGTO's Avatar
Default Guess HP
Ok I have been wondering this for a while.
Here is my specs.
2004 GTO
Motor specs.
Victor jr EFI intake
Aarons Intake Elbow
Patriot Performance Stage II 6.0 L heads
Patriot Performance springs good to 650 lift duals
Diamond -8.66 cc dish pistons teflon coated skirts and ceramic coated tops
lunati pro mod rods 6.125 length
Stock crank polished
federal mogoul berings
Diamond file to fit rings
Custom Cam 231/226 601/591 115 lsa
Tex Dual Clutch setup
Nasty Performance Stage III Fuel System
Motoron 60lb injectors.
Meth Kit
OFI T76GTS turbo kit.
HPturner 3 Bar
So how much with rwhp 15lbs of boost? Ideas?
Old 12-14-2006, 04:42 PM
98turbls1's Avatar
somewhere in the ballpark of 750rwhp...That can vary a lot though...What kind of times you looking to put out??
Old 12-14-2006, 04:53 PM
1INSANEGTO's Avatar
I want to be able to drive to the track turn up the boost run 9's and drive it home. So I want a 9sec daily driver. I will be slower on the street due traction safety issues with that much hp. But thats what they make a boost controller for
Old 12-14-2006, 06:06 PM
SSilverSSurfer's Avatar
assuming your car is full weight and you do make that power you might be able to do it, according to BMR in order to make their 4000lb GTO runs low 10's it would require the car to make 750hp. i believe eric made that much with that motor you bought from him, im buying his kit and hope ot put some good numbers down on the dyno and at the track, good luck with the project
Old 12-14-2006, 06:27 PM
1INSANEGTO's Avatar
Hey how did you know I got his motor???,....lol... He was saying once he swaped turbo it prob jumped to 800rwhp but he did not get it on the dyno.
He broke all kinds of stuff with motor, lots of transmisson and rear ends, burnt up clutchs.
My first mod that will be done once I get it going will be the drive shaft. I am trying to talk a local drive shaft shop to make one for the gto and test on my car
Old 12-14-2006, 07:18 PM
i saw you post it in another thread talking to tiago, whos the local shop your going to for the driveshaft, i got lucky with the kit im getting from him, the turbo has 125mi., lol, i cant wait to put it on
Old 12-14-2006, 08:01 PM
1INSANEGTO's Avatar
Well fedex guy (IE SANTA) came today...
as soon as I get the parts i install them. Intake elbow should be here monday or Tue
Old 12-14-2006, 08:02 PM
1INSANEGTO's Avatar
Got me... Any idea's ?
Old 12-14-2006, 08:16 PM
whered you get that intake and fuelrail set up? from edelbrock or did eric throw it in? i would look into the driveshaft that BMR is running considering they have the same goals as you, i cant think of anyone off the top of my head in houston.
Old 12-14-2006, 08:57 PM
1INSANEGTO's Avatar
BYUNSPEED $389.00 Shipped to my door!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
Old 12-14-2006, 09:03 PM
TurboGoat's Avatar
I dont know what hp your gonna make but I'll guess the time..........
11.00@135mph.......
M6 for teh lose.
At those power levels automatic baby!
Anyways I hope your not planning on running your 9second pass the first time out. I am going to push the stock motor real far before I get a built motor.
Old 12-14-2006, 09:10 PM
1INSANEGTO's Avatar
Helllllllllllllllllllllllllll no I am going to work up in stages. I will run 550rwhp for a while to get use to it.
Quick Reply: Guess HP
