Jose Dr Turbo Frcefed98....Turbosmart help!
installing the dual stage manual turbosmart boost controller....the instructions suck.I have the vacuum lines done but found your thread Jer and SR71 said to run it differently than the instructions say to....and how do you do the wiring?it has a pos and a negative off the controller and a 2 prong switch so how do u wire it to swap between the 2 settings???Help fellas
LOL went with a hallman MBC Pro after messing with the turbosmart BC...
BUT thats cuz we thought the turbosmart BC was bad. IT wasn't. My bro wired it in so I can't help out there, i'll let him know about this post to see if he'll chime in.
(I suck at wiring stuff up BIG TIME )
As for the vac lines, It went turbo-boost tee-side port of the WG, top port of the WG open, if I remember right....been awhile since I had it on the car.
J
J
sigh....ive got it top port to T from turbosmart dual stage side port to Brake booster.wiring is on controller grounded and power wire on controller runs to 1 side of the switch and then other side runs to power source.taking her out now...ill report back
so went for a drive.....with the switch off i believe i went from a 45 roll and slowly rolled into it in 4th so boost would come on slower.it slowly rose to ~6-8psi and let out.with the switch on it jumped up to 10psi fast and i let out.im tuned for at least 10psi since i never got a good pull when i dyno'd b4 he made it safe that way if i fixed the boost issue id have myself covered.only thing im concerned about now is how high boost would go if i kept my foot in it.The car even sounds different now lol,the BOV sounds pissed off and loud at hell now!
