what makes a good turbo cam
Old 12-21-2006, 09:03 PM
KHShapiro's Avatar
Default what makes a good turbo cam
just as the title says, what makes a good turbo cam
manual, street/strip
auto, street/strip
explain what and why, please.
Old 12-21-2006, 11:13 PM
BirdmanLS1's Avatar
I know i myself have asked this and ive seen so many other threads concerning this. I dont know exactly the answer but i know its out there if u do a search.
Old 12-21-2006, 11:18 PM
Possible Scammer - Buyer Beware - Issues Unresolved
00ls1's Avatar
everyone has their own opinion on this, all the different companies have different cams for their FI setups
Old 12-21-2006, 11:56 PM
KHShapiro's Avatar
I guess I could dig up an older thread, someone want to let me know when the search feature is working again ;-)
But seriously I know there are quite a few people out there that have been experimenting with some cam spec's.
Would any of you care to fill some of us (me) in.
mine is 244/244 612/612 115-0 lsa...I was planning for the 6sp but I have now changed to a 4sp auto so I am now wondering about this cam with the change in trans. I have yet to dyno
Old 12-22-2006, 12:08 AM
BirdmanLS1's Avatar
Haha, i didnt realize the search wasnt working... its weird tho, its never not worked for me, eventho i see so many other people say its not workin. I just talked to Jon at speed inc through e-mail on this very topic. He's gonna get me a cam speced for a 370 cu in. iron block setup for a TT setup. Ill let you know the outcome of the cam I get. I would talk to them about getting a custom grinded cam for a turbo application.
Old 12-22-2006, 12:31 AM
DeltaT's Avatar
I've had it crap out completely for a day or so maybe 8 times. And a couple times where it seemed like the data was wiped out or something - no results on something simple, like "turbo". Most of the time it works great.
Jim
Old 12-22-2006, 12:43 AM
black98ws6ta's Avatar
http://www.forcedinductions.com/help.htm
Also isnt your 427 going to be alittle big for that single 88mm?
Old 12-22-2006, 12:56 AM
engineermike's Avatar
Originally Posted by 00ls1
everyone has their own opinion on this, . . .
That's just it, though. It's not an "opinion" issue. That's sort of like saying that everyone has an opinion on whether or not the earth is flat. There is definitely a "right" and "wrong" turbo camshaft.
I've read alot on this subject, and the most I learned was from INTMD8's 4 or 5 cam changes in his twin turbo LT1.
Mike
Old 12-22-2006, 01:20 AM
KHShapiro's Avatar
engineermike, how much of that info do you think can be applied to an ls1.
We know they are air pumps, but one style being more efficent than another , what do you think the out comes would be?
Old 12-22-2006, 01:25 AM
KHShapiro's Avatar
yes there are opinions , but as engineermike stated there is a right and a wrong. i know a lot of guys are very competitive and about there cams and i understand completely. but a little nudge in the right direction would be very helpfull.
Old 12-23-2006, 06:11 PM
OUTLAWZ RACING's Avatar
From what I have read over lap hurts boost but people still make good power. And from what I have read people use stock and zo6 cams and make power. This is what I gather from cams in FI try and see !!! by the way mine is a 422 epp cam and gt76 wih a 96 ar. StS
Old 12-23-2006, 07:00 PM
NassyVette's Avatar
The cam you have sounds like it'll work fine. I've seen a ton of posts about turbo cams and they never end with an affirmative answer. I plan on doing some testing of my own when I finally get the motor together and running well.
Old 12-23-2006, 07:07 PM
I believe the end result would be about the same. A good set of LTx heads flows the same as a decent set of LSx heads, rpm ranges are similar, the intake/exhaust valve proximity is the same, and the cid is similar. The LS1 may make a tad more power with everything else being equal due to the better combustion chambers.
Old 12-23-2006, 07:36 PM
KHShapiro's Avatar
i am wondering about my single pattern with the Auto.
Old 12-23-2006, 07:47 PM
NassyVette's Avatar
Just checked out your fquick page and man that is one kick *** motor you have. I love the powder coated intake/pan/covers...can't wait to see what kind of power you put down. Best of luck
Old 12-24-2006, 09:59 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
You'll run into issues of running that 427ci with that turbo before you run into cam issues.
Old 12-24-2006, 07:12 PM
SSblack98's Avatar
That engine with a S88 would be killer. Really need a T6 flange for that engine. Nice setup by the way.
Old 12-24-2006, 11:25 PM
KHShapiro's Avatar
Thank you, funny thing is i have only seen the Car once, thats why there arent any pictures of it up yet. Its 80% done just wainting for me to return home to install the engine then have it painted.... i only wanted to do a light resto, and we all know how that story goes.
So you dont think that cam paired with an Auto would be an issue?
Originally Posted by SSblack98
That engine with a S88 would be killer. Really need a T6 flange for that engine. Nice setup by the way. .
really think the t4 isnt big enough?
i have/was been considerig twin pt88's
I can seem to fully wrap my head around turbo sizing and cams.I have a basic understanding , but its only enought to get me into trouble.
Like i said that cam 244/244 612/612 115lsa was for a maunal , but its an auto now.
Thanks all any more suggestion?
Old 12-25-2006, 02:38 PM
LS1Tech Co-Founder
Regarding turbo size, I'm just paraphrasing a conversation I had with Brian M. from Precision Turbo at PRI.
Back to cams. I'm running a 234/114 cam. I've run a 244/114 cam six years ago when I had a 422ci NA setup. Idled okay. You could just try it or spec out the combo with someone and see what they say.
Old 12-26-2006, 07:06 AM
MiaSSmaro98's Avatar
ive read reverse splits work well on auto but on small turbo housings
