Replaced the 2bar with a 3bar today....+ Boost.
Old 12-23-2006, 09:28 PM
Coal Mining Director
onfire's Avatar
Default Replaced the 2bar with a 3bar today....+ Boost.
Oh GAWDDDDDDDDDDDDDDDDDDDD
Fire shooting out of the tailpipes.....roasted 2 pet kittens
Actually all is good. Biggest tip is to get the scalar set to key on engine off to your actual kPa. It was only a little richer than the 2bar at part throttle. Dead on at WOT. Drove great on the 2bar tune....I'll fine tune it tomorrow.
Delphi 3bar part number 12223861 sold by Speed Inc under the FAST brand and many others...great low end resolution.....don't waste your time or money on a 2 bar map like I did.
Old 12-23-2006, 09:53 PM
LSs1Power's Avatar
Nice... What kind of injectors are you running?
Im going with the Cobalt 2.5 bar sensor. Im never going to go over 22-23psi.
Old 12-23-2006, 11:03 PM
onfire's Avatar
60lb/mn Mototrons. I replaced the Cobalt sensor...it is only a 2bar that tops out at 15psi.
Old 12-24-2006, 03:08 AM
LSs1Power's Avatar
I thought it was 2.5?
Old 12-24-2006, 09:20 AM
onfire's Avatar
That's what I thought when I bought it. 2.5 would have been plenty for me, but it's not 2.5
Old 12-24-2006, 11:18 AM
LSs1Power's Avatar
Are you using EFI or HPtuner?
Old 12-24-2006, 11:28 AM
onfire's Avatar
EFI Live
Old 12-24-2006, 11:40 AM
LSs1Power's Avatar
What is needed to fit the 3 bar sensor you listed? Does it fit as good as the Cobalt sensor?
Old 12-24-2006, 05:56 PM
gametech's Avatar
If you are using a 3bar, I wouldn't necessarily trust the little clips to hold any sensor in without leaking or blowing out. The best thing to do is tap a hose barb and run a line to remote mount the map sensor, although that would be a bitch in an fbody.
