Where are you guys mounting your meth stuff?
Old 12-27-2006, 12:03 AM
LS1Tech Sponsor
Superman09's Avatar
Default Where are you guys mounting your meth stuff?
Well i got the Snow Stage 2 meth kit for x-mas and i was looking today and am trying to find a place to mount all this stuff. Need a place for the 2 qt. tank and the pump. It says the pump has to be mounted at the same level or lower than the tank so it gets a bit tricky. Only place so far i've found is to mount the pump on the side of the bumper braced right in front of the horn vertically and mount the tank under sort of where the windshield washer tank normally is, would have to do a little custom work and brackets to get it fit as it does not want to squeeze in past that hood latch brace thingamajig...
So post up some pics of where your meth stuff in mounted in your f-body, thanks! I can make it work, just want to see what you all are doing and if there is an obvious place i'm missing. Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 12-27-2006, 07:59 AM
Turbo Addict
RICE ETR's Avatar
I copied MM's set-up....using the washer tank as a reservoir. His pump was inside the front bumper support but I cut mine up for my IC so i mounted mine right underneath the driverside frame where it sticks out to meet the bumper support...so the pump is semi on the same plain as the front of the a/c condensor if that makes any sense.
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
i'll put up some pics when i get some time
Old 12-27-2006, 08:55 AM
KraZy's Avatar
Mine is on the passenger side of the radiator, on the frame rail.
Old 12-27-2006, 09:07 AM
LS1Tech Sponsor
Superman09's Avatar
could you post some pics if possible? Thanks!
__________________
Brains's Avatar
Spare tire well holds the 3 gallon fuel cell and the pump. The solenoid, nozzle, and electronics are in the engine bay. This is the FJO water injection kit in the g/f's turbo car.
Quick Reply: Where are you guys mounting your meth stuff?
