Next step above 76GTS
Old 12-29-2006, 02:47 PM
TurboGoat's Avatar
Default Next step above 76GTS
What would be the next step up in turbo's above a 76gts for a T4 flange? This would be for a built 346 with 317 heads, turbo cam etc.
Primarily still a street car but at least 100 passes a year at the strip
oh and it needs to be physically almost the same size as the 76
Old 12-29-2006, 02:56 PM
Smearin's Avatar
76 is good for that size motor why would you want to go bigger?
80 would be next... or a 76 t6 flange.. or a s76
Old 12-29-2006, 03:05 PM
TurboGoat's Avatar
I am not sure that I will just thinking ahead, maybe going to a 370, I am also trying to learn too about the various sizes etc.
Are the S stuff T6 flanges?
Old 12-29-2006, 03:07 PM
Smearin's Avatar
Yea they are.. they're awesome units..
76 would be perfect for a 370 or 346.. I think you can upgrade wheels on the 76 to 80.. not 100 % tho..
maybe someone will chime in on that..
Old 12-29-2006, 03:10 PM
LS1TECH Sponsor
DrTurbo's Avatar
Go with a GT-M from T-netics. They are a bit pricey but awesome pieces and use a T4 flange.
LS1TECH Sponsor
DrTurbo's Avatar
BTW, the S-series turbos are T6, but they will make crazy amounts of power and are pretty much indestructible.
Old 12-29-2006, 03:12 PM
TurboGoat's Avatar
Where is that on your site? I dont see GT-M under the t-netics section
Old 12-29-2006, 04:10 PM
LS1TECH Sponsor
DrTurbo's Avatar
We have not added them to the site yet. They are deinfitely beasts.
Old 12-29-2006, 04:26 PM
frcefed98's Avatar
Are they available from T-netics now??
Old 12-29-2006, 04:30 PM
SuperZ's Avatar
I run a GT-42 76mm with a T6/I love it.Im sure there is newer better things out by now though
Old 12-29-2006, 04:31 PM
LS1TECH Sponsor
DrTurbo's Avatar
Through us yes, and I believe only us for now.
Old 12-29-2006, 04:36 PM
frcefed98's Avatar
Cool send me a GTM-1000 and i'll put it on and send back this TC76 back to you guys
J
Old 12-29-2006, 04:47 PM
SuperZ's Avatar
J
how is your car doing with that TC now??
Old 12-29-2006, 06:31 PM
Hennytime's Avatar
is the the only differences between the t and s series? what are the spool characteristics between the two?
Old 12-29-2006, 06:48 PM
Smearin's Avatar
the s series are mid framed.. and from what Dr. Turbo has told me.. they are the same size as a gt42
theres a thread in here that tells the spool of the s-series but i hear they spool quicker in comparision to smaller turbos
Old 12-30-2006, 08:28 AM
MIGHTYMOUSE's Avatar
the largest t4 (and the only step up imo) is the pte-88 and it is larger all over than a 76
Old 12-30-2006, 09:07 AM
smokinHawk's Avatar
the compressor section is the same size as a 76gts, but the bearing section and exhaust housing is a little bigger.
Old 12-30-2006, 09:51 AM
TURBO383WS6's Avatar
i'm running a T76GTS on my 383 w/ absolutely no probs right now. i was told that when i decided to upgrade, the only thing else that would fit was an 80mm of some sort.
Old 12-30-2006, 10:30 AM
engineermike's Avatar
Originally Posted by TURBO383WS6
80mm of some sort.
Yea, forcedinductions.com sells an 80 mm compressor upgrade for the 76GTS. However, as he told me, if you're not doing 150 mph in the quarter, then you haven't reached the limit of the 76 yet.
Old 12-30-2006, 11:19 AM
LS1TECH Sponsor
DrTurbo's Avatar
The PT88 is a possible next step, but most folks don't want the extra lag that comes with a TV unit.
