How well do gears affect us F/I guys? mainly SC stuff
I recently bought an 02 z06 that has a procharger and some bolt on stuff.. Makes 570whp and have been curious but haven't read much about doing gears with the setup.
I know some guys have had luck with turbo's and like 3.00 gears but have seen some stuff where a 3.90 or 4.10 can really help too with the s/c guys.. Any threads or info to help decide what a good option for me is? Currently have the stock 3.42 and car pulls pretty good...
What type of gains will I notice going higher gear? Better et? Or just mph? Or both?
Thanks..
Thanks..
Is it an A4 or M6? Well, the main thing about lower gears is that it will get you into your powerband quicker. I.E. it will aid in quicker spool up which can lead to better e.t.'s.
The z06 6speed has different ratios than the standard c5's. I've always heard the first few gears it acts like it has 3.90's already. Personally, I think if you add higher numerical gears to your setup all you'll see is a smoke show.
Gears dont mean anything for a supercharger since they dont 'spool up' like a tubo, a blower's rpm and output is dictated by engine rpm.
A centrifugal blower has a very simiar powerband to a n/a engine, in a M6 Z06 it would depend on where you want your top speed in 4h gear at max rpm to be like anything else. The Z06 trans does have a higher 1st gear then the standard M6, I would assume the standard 3.42 would be fine unless you are going to good tires and are worried about dragstrip times.
Originally Posted by kp
Gears dont mean anything for a supercharger since they dont 'spool up' like a tubo, a blower's rpm and output is dictated by engine rpm...
Originally Posted by 6techniques
Thats true, but regardless of if a car is N/A or not, wouldnt gears cause cause the effect of one to "ramp-up" quicker, thus giving an effect of a quicker "spool", for lack of a better term? Like for example, if you took out those 3.70's and put in say, 3.24's, wouldnt that effect how fast your car gets into its powerband?
Turbos tend to spool quicker with more load, smaller number gear can help spool quicker but that isnt related to a supercharger at all.
you want as much gear as you can get, period.
pick your tire size, pick your max rpm, pic your high gear ratio, pick a desired maximum trap speed, and do the calculation...or use an online calculator...and thats it.
for instance i want to run a 27" tire, not go past 6800rpm, high gear is 1:1, and i want to go a max of 150mph trap speed. this came out closest to a 3.42 gear for me so thats what i got.
TT-TECH Veteran
Well I have a little bit of a different view on it from my experience (Mainly on the street though.). The FI cars tend to like the taller gears a little more. I wouldn't go too crazy, but a good 350ish gear is hard to beat for all around performance. ZO6's gear ratio's suck for a big powered FI car. They are too low in first and second causing it to spin way too easy and when you go to the next gear it too is so close that you need to shift to third then you end up being in third when it finally hooks and then you are out of your power range for a few seconds. Ends up letting people get out on you a little. Drivers do make a difference, but a little taller gear rations of the M6 gears are better suited for a FI car IMO. Traction is a huge issue once you get to a certain point. I am basing this off a friends car I helped him put together and He is not the best driver, but not the worst either.
LS1Tech Co-Founder
Having owned a blown setup in the Formy, and also a stock Z06, I would say that I would never put more gear in a Z06 unless you are running sticky tires.
When I converted my Formy from NA to FI, to a blower setup for a few years, I had 4.10's and then went to 3.50. The 4.10's were much more limited. I ran 3.50's with 28's, could have run 3.73's, but it was not worth it to me. But class race cars would probably err on the side of being slightly overgeared, rather than under.
in my opinion 3.42-3.73 is where you want to be. but like inspector 12 said it depends on your trans how it is geared.
if and when i do my 12 bolt i'm just gonna stick 3.42's in there, i have 3.23's now, it wont make a big difference but it will help bring the revs up quicker. I'll be running a 3800 yank now so that's all the gear i'll need.
i wouldn't fix anything unless its broke.
maybe do something else like add nitrous
