Street build critique
I want a very reliable 450-500rwhp I can use whenever I want, 25mpg, and decent driveability. I don't want it to sound like the the pro stock class decided to do some racing in the company parking lot at 7am either. I won't be able to start until May-June (when I get my signing bonus, and start working), but I'm just trying to make sure everything is accounted for so I know how much $$ I'm going to need.
Here's what I'm thinking:
Car:
1998-2000 z28 m6 w/ low miles ($10k)
Engine:
Used STS Turbo @ 5-8psi ($3000)
Comp 918 Valve Springs ($175)
Ford Green Top 42# injectors ($250)
LS6 oil pump ($100)
LS6 Intake (used $250)
Walbro 255lph fuel pump ($175)
Tuning ($300)
Alky/Meth/Water Kit ($300)
Gaskets/misc parts ($200)
Driveline:
Spec Stage 3 Clutch ($400)
T56-Rebuilds Stage 3B build ($1565 + shipping)
Accessories:
Boost gauge ($100)
Total: $16,815
Car:
Engine:
LS6 oil pump ($100)
Tuning ($300)
Driveline:
Accessories:
Boost gauge ($100)
Total: $16,815
As for a history, I owned a 95 z28 m6, and did the following mods:
xe224/230 112 cam
ported stock heads
spec stage 3 clutch
150 wet shot
slp headers
hooker catback
3" cutout
k&n cai
msd digital 6+
etc etc
Not exactly new to this...
xe224/230 112 cam
ported stock heads
spec stage 3 clutch
150 wet shot
slp headers
hooker catback
3" cutout
k&n cai
msd digital 6+
etc etc
So Frost, whats the verdict then on the rear mount kit on the street only. Will it give me safe and reliable power up to 500rwhp? Would a heads/cam/n2o setup be any faster, safer, or more reliable, considering I cut no corners on either setup?
There is no real answer here, or at least not one, need to read and decide what fits within the boundaries that you have set. I was just trying to point that one thing out.
Ok, thanks for the insight. So as far as the engine parts list is concerned, does that look about as 'safe' as it can get for 500rwhp on a stock bottom end?
Also, would a heads/cam/n2o going to be 'safer' in terms of snapping a rod, cracking a piston, spinning a bearing, etc etc.
