People with MP70s...
Old 01-07-2007, 07:55 PM
Snyper's Avatar
Default People with MP70s...
What kind of power are you making on or around 10psi (6 speed). I just bought one and I plan on running 10psi from a 355 with around 8.3:1 compression with a small cam. Any of you bring it to the track yet? Also, what kinda problems have you experienced with this turbo? Thanks.-Mark
Old 01-07-2007, 10:23 PM
Smearin's Avatar
im running 7.5psi @ 533rwhp..
tho I was told my 70 was a garrett, until I did some research..
I would never buy one, but then again, it hasnt given me any problems..
tho I hear bad things about mp all the time...
Its just worth the extra$$ to get a garrett, precision, turbonetics.. etc
Old 01-07-2007, 10:26 PM
Turbo LS1 SS's Avatar
not a big fan of MP either. unless it can be had uber cheap, i wouls pass on it. if you can, get yourself a 76mm, give yourself room to grow. you will be happier
Old 01-08-2007, 12:26 AM
Snyper's Avatar
I got a brand new one never used for 500$ 1 year warantee
Old 01-08-2007, 12:28 AM
Snyper's Avatar
anyone with any information you have on your experiences with these turbos..im not really looking for "ive heards" or "people say" cuz ive proved alot of those wrong and I know some people just have bad luck...just want some info..hoping to make around 550rw on 10psi with it..and drive on the street..not looking to go 9's lol
Old 01-08-2007, 12:36 AM
i have no personal experience with them, but the turbo guys like "Dr Turbo" and "Jose@ForcedInductions" always rant about how many MP rebuilds they get ALL THE TIME...and how they are overall crappy units.
buy quality parts once, not shitty parts twice
Old 01-08-2007, 12:49 AM
Snyper's Avatar
i get that but im sure part of the rebuilds have to do with improper instal and other things done by the buyer. Theres alot of people on here whove had no problem with them...hopefully ill be one of them. =)
Old 01-08-2007, 07:30 AM
Boostaholic's Avatar
Well my car had serious problems with not revving past 5500 rpms, but it still manages to make 550 hp, 600 tq
Old 01-08-2007, 09:06 AM
coop5885's Avatar
im currently got my car torn down to upgrade to my PT88, but i never had a single problem with it. It made boost fast, held it, and made good power all the way to 7000rpms. If you have it, use it. You will love it, but make sure it has a .96ar hot side.
Old 01-08-2007, 01:36 PM
Snyper's Avatar
Yeah, mine came with a .96 A/R housing. Ill be using "as cast" trickflow 62cc heads(I traded my better flowing stock LE2's)...while I know the LE2's flow better (cuz they are ported) I traded for the bigger CC's(62 instead of 56) to bring the compression down to where I wanted it to around 8.3:1 not to mention I have much more room to grow next year when I get these heads ported. Did you have it with the 370cid? or the stock 346? Mines a 355 and im wondering when it comes into full boost..
Old 01-08-2007, 05:17 PM
Smearin's Avatar
I thought .96 would be great.. I have a .68 and its perfect for the street..
.96 is big.... I would try a .81..
Old 01-08-2007, 06:11 PM
Snyper's Avatar
I want the operating range to be from 2500-6000..(ill be shifting at 6k)
Old 01-08-2007, 06:45 PM
Tiago's Avatar
two of them work for me, at 18 psi - 1000 rwhp
Old 01-08-2007, 06:55 PM
Snyper's Avatar
thats what I like to hear....anyone else?
Old 01-08-2007, 07:05 PM
Smearin's Avatar
with a .68
Old 01-08-2007, 07:24 PM
Snyper's Avatar
damn..well i have 10 more ci than you..not sure if that means anythinglol..but i was told the .68would be wayto small
Old 01-08-2007, 07:40 PM
Boo"SS"t's Avatar
I had a MPt70/.96ar on-center turbine w/ my old set-up, tti street kit on stock motor w/ 6spd except for a cam. At 9ps it made 467hp/499tq @ the wheels on "mustang dyno" w/ only 14deg on 92oct, so on dynojet it should be aprox. 567/599? maybe more w/ more timing and some mixed race gas. I only had that set-up for about 3-4k mi. but the turbo came on strong from 3,000 up to 6,200rpm. All in all, it was a descent turbo for the small price especially if you're in a tight budget, i just did'nt have it long enough to find out it's durability.
Old 01-08-2007, 07:45 PM
Tiago's Avatar
0.68 si hte A/R I run on the 3.8L fbodies I build, thats way too small on a ls1, backpressure is prolly through the roof.
hell I run TWO of them...
Old 01-08-2007, 09:07 PM
Snyper's Avatar
well thats what im looking for hoping power is on pretty good by 3k up to 6...and i figured anything under a .81 would be too small...
Old 01-08-2007, 09:49 PM
Project GatTagO's Avatar
Received 1,393 Likes on 879 Posts
I have a MP T70 with a tang .96 A/R turbine housing getting ready to go on a 5.3L project.
Andrew
