The Ultimate Turbo Cam
Please help sellect the ultimate turbo cam. I bought a cam already but am told it isnt optimal for turbo aplications. I am looking for the chunkyness of a big cam yet optimal for turbo applications. some suggestions were:
1. 228 224 with a 116LSA
2. 224 224 with a 116LSA
add your coice and please leave reasons why: Im sure this will help many when choosing a cam for their forced induction project.
THANKS ~Guy
THANKS ~Guy
There is a lot more to a camshaft than duration @.050 and the LSA. If you don't know or don't understand what else there is you would be best served by contacting a reputable camshaft grinder or turbo tuner and asking there opinion. At the end of the day they charge the same no matter what lobes they put on a cam core and they do it every day and make a living at it. There isn't anyone that I could think of that would be more qualified to help you. Most folks here mean well but wouldn't have the depth of knowledge that a professional would.
Like T/A said, there are SO many factors that go into cam selection, and most of them are based on your specific engine's characteristics. For some good information and formulas, try the Tech section on ForcedInductions.com.
Turbo 101
The words overlap sometimes which can make it hard to read, but just highlight the paragraphs and you'll be alright.
Turbo 101
No such thing. Every combination is different and will have different requirements. I have seen pretty close to the same combinations running very different cams with very close to the same results. There have been multiple threads about this. Do a search and I can promise you one thing, you will be even more confused than you are now. Everybody seems to have different opinions. I say pick a sponsor and contact them. They know what they are doing.
Thanks Hamrhead, Im going to go with Speed Inc.s turbo cam. the guys down there are nice and seem very knowledgable. Im going to go with their turbo cam which is
225/225 .581 .581 113LSA he said it will give me tons of power and the chunkiness I am looking for. Thanks again ~Guy
As others say, no such thing......and optimal in what way ??? No cam without hours and hours of actual testing will find you what is optimal.
Also....
https://ls1tech.com/forums/search.php
Also....
Perhaps thats why he created this post? To see what people are using in what combo and how it works. Just a thought, I could be wrong. Perhaps someone out there tried a certain grind and gained a tremendous amount of power? Anyone can call a cam maker, Im sure they know their **** to a point, but no one knows more than the people than actually run, test and tune them. Probably another reason he was asking in this section.
Im not being rude, I just hate asking a question on here and being told to call someone. I mean if I wanted to call someone I would, but then you get one answer. vs. on here you get a few answers, people picking them apart, and reasoning, and fallow ups and what not.
Back to the subject of an optimal turbo cam. What out there has worked wonders on what setup? Theres setups out ther with tons of things done making good numbers, then theres setups out there with minimal stuff done exceding those, How crucial is the camshaft selection in a turbo car?
I just used my freinds 224/224 .580/.580 112 and it seems to work fine. 5.3L 8.6:1 , ported 6.0 heads, 15psi boost.
Not to hijack his thread but what other info would be needed to determine what would be a better cam? besides testing each one. Like would an LS6 cam be better? about the same? WAY better?
The stock LS6 cam will work very well on a turbo build, in fact dozens of cams will.
IMO, when it comes to a turbocharged setup, things like turbo selection, tuning, manifolds, BOOST, CR, heads etc, will have more of an impact than a camshaft.
Although.....a big camshaft can seriously hurt driveability and power/torque at lower rpms. It may help up top.....thats another debate though. IMO what you would lose down low, isnt worth it, unless you want a lopey cam.
If one setup doesnt make enough power, turn up the boost.
Now, back to the original question. He hasks what cam would be optimal for a turbo build....
Are we talking a 1000cc 15,000rpm motor, or a 427ci 6000rpm motor ? What car, what engine, what turbos, what useage ?
Its hard to advise someone who asks a totally open ended question.
How long is a piece of string ??
And as I said, use the search facility. These questions have been asked so many times, and there is a wealth of information in this forum, from people who have asked similar questions, albeit a little more specific.
