ProCharger belt - pulley matrix 6 and 8 rib F-Body
The attached documents detail the appropriate belt to use with each pulley combination. When reading the ProCharger belt part numbers, such as DB415I-008, the first three numbers describe the length of the belt. The previous number is a 41.5" long 8 rib belt.
No boost numbers are given due to individual engine combinations.
I hope this helps some of you. It might be good to print out and keep with your manual or in the car just in case.
Revisions to these may occur from time to time.
edit: Changed some 8 rib applications to use 41.5" belt due to installation difficulty.
Originally Posted by SRZ
You have that also for 12 rib? Or are they the same as the 8 rib?
You are thinking of a LT1.
He listed the stuff for a LS1 car.
The LT1 8 and 12 ribs are much different combos.
EA
