will 8 psi work with 64cc heads?
Old 01-13-2007, 07:12 PM
venom ws7's Avatar
Question will 8 psi work with 64cc heads?
HI guys my friend just found stg 2 patriot head WITH 64 cc and he wants to run it with vortech 8 psi he has stock pistons and he is not planning to run high boost now .
so will it work stock comp with 8 psi and 64cc heads?
THANKS IN ADVANCE.
Old 01-13-2007, 09:59 PM
venom ws7's Avatar
anyone? plz
Old 01-13-2007, 10:03 PM
Got Me SOM's Avatar
he can probably get away with it but his fuel system will be to be on par and his timing should be very conservative.
Old 01-13-2007, 10:06 PM
Turbo LS1 SS's Avatar
compressions prolly around 10.5:1
Old 01-13-2007, 10:11 PM
Got Me SOM's Avatar
i would keep timing around 14-15 degrees and keep the air fuel ratio at around 11.5:1 minimum. should run good and have a lot of torque.
Old 01-13-2007, 10:20 PM
venom ws7's Avatar
Got Me SOM and Turbo LS1 SS thanks for the help guys.
Old 01-13-2007, 10:23 PM
Got Me SOM's Avatar
no prob post up the results asap
Old 01-13-2007, 10:43 PM
venom ws7's Avatar
sure we are going to the dyno in a couple of days
my friend is hoping for 500rwhp do you think its possible with these mods
ha has:
full exhaust.
MTI stellth cam.
ls6 intake ported TB.
stg 2 heads 64cc
vortech v2 8 psi with air to water aftercooler (not sure about the cooler) 3.46 gears and the car is A4
