A true Turbo Guru will know what this pic is.
Old 01-19-2007, 10:22 PM
Coal Mining Director
onfire's Avatar
Default A true Turbo Guru will know what this pic is.
What is it?
Attached Thumbnails A true Turbo Guru will know what this pic is.-img_1232-medium-.jpg   A true Turbo Guru will know what this pic is.-img_1233-medium-.jpg
Old 01-19-2007, 10:50 PM
Smearin's Avatar
A retriction....
An old school Wastegate
Old 01-19-2007, 10:51 PM
onfire's Avatar
1. Opposite
2. nope
Old 01-19-2007, 11:07 PM
TT-TECH Veteran
Inspector12's Avatar
Looks like some home made intake piping and a place for Meth or No2 injection?
Old 01-19-2007, 11:20 PM
99f1's Avatar
Default Lol
A Big *** Steam Roller
Old 01-19-2007, 11:25 PM
alwaysinboost's Avatar
where did you get that, do you know what the ID & OD is?
I think it's an adapter for the compressor inlet of a SC.
Old 01-20-2007, 12:43 AM
xssive's Avatar
Looks like the Incon tt intake stepped up to 4" for a 90mm tb???
Old 01-20-2007, 03:31 AM
ninetres's Avatar
Two pieces of pipe welded together with a hole tapped in it. Duh, what do I win?
Old 01-20-2007, 04:11 AM
Mike 01WS6's Avatar
It does a bit.
I have no clue what the hell it is. I don't know **** about ****.
Old 01-20-2007, 04:24 AM
LS1AC-Cobra's Avatar
what ever it is, it's definately not an work of art....
Old 01-20-2007, 05:51 AM
cablebandit's Avatar
looks like a copy of the incon transition
Old 01-20-2007, 05:56 AM
gametech's Avatar
Looks like somebody with a hammer, two hits of acid, and a welder got bored.
Old 01-20-2007, 07:53 AM
stevieturbo's Avatar
An over-complicated shape, to plug up one end of a plumbing system to test it for leaks ?
Old 01-20-2007, 08:15 AM
maybe it steps an intercooler over the radiator support....
do tell!!!
Old 01-20-2007, 09:53 AM
EGash's Avatar
Intake Leak tester with offset for engine mount clearance on bottom mounted TT setup?
Old 01-20-2007, 10:05 AM
kp
kp's Avatar
Giant crack pipe.
Old 01-20-2007, 10:17 AM
6techniques's Avatar
Originally Posted by kp
Giant crack pipe.
after you said that, it does kinda look like one!
Old 01-20-2007, 10:22 AM
Ed @ Late Model Speed's Avatar
Throttle body intake transition for an F-body turbo setup, if I had to guess judging from the quality, I would say something from RR?? Is that one of the few parts that actually got installed on your car? I don't remember seeing that, but it's been awhile
Ed
Old 01-20-2007, 11:59 AM
W8N2SQZ's Avatar
Code:
Giant crack pipe.
Old 01-20-2007, 12:19 PM
onfire's Avatar
xssive, Cable and Ed are very close. It's an Incon maf transition tube that's been opened up for a 90mm tb, extended to eliminate the maf and drilled for a meth (or crack) nozzle.
After I finish sanded and coating it will look a lot better....it's just been welded and tumbled in the pic. Fits like a glove between the tb and Incon y pipe.
kp makes a valid point though, you have to be on crack to FI an Fbod...no room for anything on these cars.
Quick Reply: A true Turbo Guru will know what this pic is.
