How Much Boost and How Much Power with 10.2 Comp Ratio
I am getting anxious of course with winter being here and curious on what you guys think. My setup unfortunately will have a lot more compression than I would like, but that is how it must be for now. So my question is, how much boost do you think I will be able to safely run and what kind of power do you think that it will make. Thanks in advance.
3.905 Bore
4" Stroke
71cc professionally ported/polished LQ9 heads with Comp 921's and inconnel valves
GM .052 MLS Gaskets
233/239 114 Cam
-7cc Diamond Pistons
Piston to Deck -.015
Rear Mounted Precision 76GTS Turbo
Meth Injection
75lb Injectors
255 In Tank Pump
2nd 255 External Pump with secondary lines
93 pump gas
3.905 Bore
4" Stroke
GM .052 MLS Gaskets
233/239 114 Cam
Meth Injection
75lb Injectors
255 In Tank Pump
93 pump gas
The tuner has been in the business for many years and I have a lot of confidence in that department and yes, there will be a Bell single front mount intercooler in addition to the meth injection. Thanks for your response.
