Procharger Fbody mounting Brackets
Old 01-23-2007, 02:59 AM
SinCityFD's Avatar
Default Procharger Fbody mounting Brackets
Hey guys where do you go if you only need the brackets? Also has anyone used any aftermarket brackets for the Fbody to mount a procharger?
Old 01-23-2007, 03:56 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com....html?item=966
http://www.exoticperformanceplus.com....html?item=967
http://www.exoticperformanceplus.com....html?item=968
I also have a lot of the little hard to find parts listed on my website for the ATI ProChargers on LS1 F Body vehicles. Bob
Old 01-23-2007, 04:19 AM
SinCityFD's Avatar
Hey bob do you guys ever sleep over there I spend hours on your website reading the builds you guys do it amazing.
Do you happen to know if the 8rib is much wider then the 6rib? I have very very tight space in the rx7 so I need everything as narrow from the motor to the front of the car as it can be.
Old 01-23-2007, 11:20 AM
Brent@LPE's Avatar
the six rib belt measures .883 and the 8 rib is 1.110 belt width,the pulleys are 1.140 for a six and 1.420 for a 8 rib .I hope this helps!
Brent
