any high HP FI guys have experience w/ coating???
i'm in the middle of building my 408ci GT47-88 setup.
I'm taking my time w/ the build trying to do everything right the first time.
i have limited knowledge on coating the pistons, side skirts of the piston, exhaust ports, etc.
there's not many threads on tech other then this one:
https://ls1tech.com/forums/showthrea...ing+combustion
but thats a year old.
At first i thought people just coated the piston tops to help prevent melting upon lean conditions, etc. But upon reading that thread it seems you can coat piston tops, side skirts, exhaust ports, etc etc.
i wanted to PM Dart331Stroker since he had a wealth of knowledge and said he worked for Dart as the:
Dart Machinery Ltd.
Technical Department Manager
New Product Engineer
but he hasn't posted since 11/06. i'm not sure if he frequents the board.
any information is appreciated.
Dart Machinery Ltd.
Dart Machinery Ltd.
Dart Machinery Ltd.
Originally Posted by V6 Bird
I will say this. On my engine the pistons are coated on the top and the skirts are coated with something else. These are custom JE pistons. For high horsepower cars, it will give you a small amount of screwup before catasrophic damage occurs. At least thats what my engine builder explained to me. That and it will help keep the piston cooler under extreme cylinder pressures and cool off quicker as well. More importantly it puts the heat into the chamber and not the block. More heat in a chamber itself will generate a more complete burn for more hp.
thats pretty much what i've gathered from reading. i more then likely will have the piston tops and side skirts coated, but wanted to see if anyone had experience or benefits from coating the exhaust ports, etc.
Sawzall and Welder Mod
In regards to chamber/piston coatings, I recommend doing everything or nothing. By everything I mean the tops and skirts of the pistons, the faces of the valves, the chambers and exhaust ports.
Coating the chambers and valves will theoretically increase the surface temps of the piston if the piston was bare, and vice versa. In N/A apps. this isn't much concern, but when EGT's and cylinder pressures are elevated with forced induction, you need to be careful.
