Will my fuel system support 13.5 lbs boost?
Old 01-25-2007, 12:20 AM
JD_Z28's Avatar
Default Will my fuel system support 13.5 lbs boost?
I'm running twin Walbro's with 60# Motron injectors and I'm still on the stock fuel rails and lines. With my current setup I'm making in the 550-560whp range. I'm finally upgrading my turbo to a TC-T76 from Forceinductions.com. Do you guys think my fuel system will support 13.5 lbs of boost, right now I'm only running 9 lbs.
Old 01-25-2007, 06:10 AM
lmt0705's Avatar
I was told by mike of new era performance that dual intank 255lph walboros will support 800 rwhp with stock rails and a hotwire kit. thats the setup im going to use with 60 lbs injectors also. I will be running around 16 psi expecting around 700 to 750 rwhp.
Old 01-25-2007, 06:42 AM
Frost's Avatar
I'm at 15.5psi on the street with meth. My dual pumps fixed my leaning out issue.
Old 01-25-2007, 10:25 AM
JD_Z28's Avatar
I'm not really concerned about the pumps, I'm more worried that the fuel lines and rails being to restrictive.
Old 01-25-2007, 10:28 AM
anarchy99's Avatar
I don't think it will be a problem. I'm not on the stock rails still but I am on the stock lines with dual in-tanks and 60 lb injectors. No problems.
Old 01-25-2007, 10:53 AM
JD_Z28's Avatar
How much boost/Whp are you making?
Old 01-25-2007, 11:08 AM
anarchy99's Avatar
no idea on WHP since I haven't dynoed yet, but right around 13 psi to date so far.
Old 01-25-2007, 11:15 AM
JD_Z28's Avatar
I figure with 5 lbs more I should be around 660 whp. Will it be safe to make that much power on the stock rails, lines, and regulator? Do you guys think I can achieve this much power on 91 ocatane?
Old 01-25-2007, 01:55 PM
Frost's Avatar
Rails are cheap. Buy some.
Old 01-25-2007, 03:17 PM
JD_Z28's Avatar
I'm going to be getting the rails and lines sometime next month. The car's getting tuned next friday with the 13.5lb spring so I wanted to make sure I would be OK with the stock rails and lines
Old 01-25-2007, 03:46 PM
BOONE's Avatar
I would get the regulator and rails and a return line. I think you will develop a problem soon. I did, fp kept falling, above 650hp, just hit a wall. Im still working on mine, not finished with it yet.
Old 01-25-2007, 04:36 PM
SuperZ's Avatar
I have 1 255 intank and stock lines ans rails with moto 60s with meth.I run 14psi on T6 turbo.A 50 shot to at times.Maybe im just lucky
Old 01-25-2007, 04:50 PM
LS1Tech Sponsor
Slowhawk's Avatar
I wouldn't risk it.You won't know if they hold till it's too late.Atleast run a return line from the rails.
Old 01-25-2007, 05:16 PM
MiaSSmaro98's Avatar
return line to a regulator or to the tank?
Old 01-25-2007, 05:50 PM
black98ws6ta's Avatar
Do you have the second pump comming on with boost? I think it will be fine, I have made 650 rwhp dyno jet on 93, 15 psi, stock rails, lines and one intank. Do you have a fuel pressure guage and wideband in car?
Old 01-25-2007, 06:03 PM
bifster's Avatar
is this a front mount system?
Old 01-25-2007, 06:10 PM
JD_Z28's Avatar
bifster: I'm runing a rear mount setup with a TC T-76.
black98ws6ta: I'm not runing a fuel gauge or wide band yet. I have my second pump comming on under boost. Like I said I'm going to be probably making in the mid 600's, hopefully everything holds up with a good tune
anarchy99's Avatar
sts setup.
Old 01-25-2007, 06:36 PM
If the car makes mid 600's then that will be about it, even at that hp it will be dropping fuel pressure im sure.
Old 01-25-2007, 06:44 PM
JD_Z28's Avatar
I hope I'm making the right decision runing 13.5 lbs of my fuel setup
Thanks for all the avdice you guys, now I have to just wait and see
Quick Reply: Will my fuel system support 13.5 lbs boost?
