ported compressor housing (turbo)
Old 01-28-2007, 11:11 AM
Rusted40's Avatar
Default ported compressor housing (turbo)
how much does it affect the surge line and pressure ratio?
I have been told it just widens the map in both directions.
too good to be true? disadvantages/downside?
Old 01-28-2007, 11:41 AM
lt170chevelle's Avatar
that is sweet very impressive setup
Old 01-28-2007, 11:50 AM
engineermike's Avatar
That was my comment excactly. This poor guy can't get any tech support from the boards becuase everyone just gawks at his pic's. . .
Rusted, are you talking about enlarging the volute? If so, that would be very hard to do uniformly. It would basically increase the compressor A/R, which moves efficiency out to the right. I don't think it would affect surge though. I'm trying to get Jose to send me an S76 compressor cover for my 76GTS for that very reason.
Mike
Old 01-28-2007, 03:34 PM
Rusted40's Avatar
http://turboneticsinc.com/turbo_gtk.htm
no, more like the indexed holes drilled around the inlet on the horn
I've seen several variations of this on different makes.
Old 01-28-2007, 09:36 PM
Oh. I'm pretty sure that's simply to move the surge line to the left.
Old 01-29-2007, 10:16 AM
LS1TECH Sponsor
DrTurbo's Avatar
Yes that is all the re-flow covers do is move the surge line to the left. Does not effect HP output.
Old 01-30-2007, 10:26 AM
Rusted40's Avatar
would it be better if I just upgrade my compressors from t-64's to t-66's
I notice the 64's arent even listed in the new turbonetics book.
also the exducer on the 64 is actually larger than the 66mm.
the surge line on the 66 is a little farther to the left and the center effeciency island is much larger. its almost a no-brainer.
it looks like the 64 would be better suited for a mild single build
