ati plastic plentum, how much boost can it handle?
Old 02-04-2007, 05:33 AM
lmt0705's Avatar
Default ati plastic plentum, how much boost can it handle?
I was just wondering how much boost you guys are running on the stock plastic plentum for the procharger. on my last setup at just under 11 psi I thought that thing was going to pop, now that im going with 14-16 im a little concerned that it might. also are there any performance advantages to going with a metal one? does anyone make them cheaper then ati?
Old 02-04-2007, 06:19 AM
EPP
EPP's Avatar
I ran it on my own '99 Z28 at 15 psi without any problems. Bob
Old 02-04-2007, 06:57 AM
lmt0705's Avatar
would there be any performance advantages to going to metal to prevent the expanding of the plentum? I think you told me when I was at your shop that you had seen one pop
Old 02-04-2007, 07:51 AM
turbo'd stang's Avatar
We ran one on an engine dyno and it popped at 12psi.
Old 02-04-2007, 05:38 PM
EPP
EPP's Avatar
Question
Certainly without the expansion, the boost would be more immediately forced into the engine. The difference though is probably so small that it would not be detectable. Hard call, several plastic ones have come apart, although they have a good track record. The metal ones would soak in some heat on the other hand... Bob
Old 02-04-2007, 08:49 PM
bandit1's Avatar
Well I have the polished metal one and its just as prone to probs I was chasing a boost leak and just found out that the entire weld on the bottom had come apart we acually got it welded yesterday and now am seeing a full 12 psi all the way to redline and a full 8psi at 2800 which is WAY fun!!!!
Old 02-05-2007, 09:56 AM
Bad30th's Avatar
I popped a plastic plenum on the first dyno pull on 9psi. ATI was really cool about it and RMA'd it and let me upgrade to the polished aluminum one for cheap.
Rob (Bad30th)
Old 02-15-2007, 03:10 PM
Bad30th's Avatar
Haha, as a followup to this, I just popped my aluminum one too, at about 12psi.
Yes, that's antacid next to it, I got a stomachache when I thought I popped my new motor haha.
Rob (Bad30th)
Old 02-15-2007, 03:13 PM
bandit1's Avatar
Rob (Bad30th)
Dam thats exactly how mine looked too ATI needs to look into this!!!! I solved mine with a new custom front mount
Attached Thumbnails ati plastic plentum, how much boost can it handle?-pic021407_7.jpg
Old 02-15-2007, 04:08 PM
lmt0705's Avatar
sounds like im better off fabing making up my own then buying the procharger garbage
Old 02-15-2007, 04:49 PM
andereck's Avatar
Rob (Bad30th)
Please call ATI and they will try to make it right for you. Sorry for your trouble.
Old 02-15-2007, 04:59 PM
Bad30th's Avatar
Just called, they won't do anything for me since it's over a year old... Of course they will sell me a new one... They recommended visiting a local radiator shop that could weld aluminum and getting it patched up...
I'm going to fab up something with pipe and get rid of the plenum, or move to a front mount, haven't decided yet...
Rob (Bad30th)
Old 02-16-2007, 09:22 AM
No Juice's Avatar
If you don't want the front mount you could go to a "butt pipe" similar to the Incon turbo kits and keep the twin intercoolers
Old 02-16-2007, 09:25 AM
Bad30th's Avatar
That's exactly what I thought of. To spoil the surprise, I am having something similar to the incon pipe fabbed up out of 2.5" polished stainless. Should work great and look great too.
Hopefully it will be complete early next week, I'll post pics.
Rob (Bad30th)
Old 02-16-2007, 09:27 AM
No Juice's Avatar
Sorry Rob, I didn't mean to spoil it for ya.
I can't wait to see it!!
Old 02-16-2007, 02:27 PM
Packy's Avatar
Rob (Bad30th)
Mine did the exact same thing in two places.
Old 02-16-2007, 03:26 PM
WHPLASH's Avatar
Wonderful, I just bought one.
Old 02-16-2007, 11:46 PM
lmt0705's Avatar
where did you buy one from? how much was it?
Old 02-17-2007, 12:10 AM
Rickys S/C Z28's Avatar
well i was thinking of buying one but not now thanks guys!!
Old 02-17-2007, 07:54 AM
EPP
EPP's Avatar
Smile
We've never had a problem with one yet. I wouldn't worry about it. Bob
Quick Reply: ati plastic plentum, how much boost can it handle?
