Oil lines for turbo
LS1Tech Sponsor
Feed (-4an). drain (-10an) For feed, tap into oil block which is right above your oil filter, has a spout on it, drill that out and put a fitting on it and connect for feed. For drain you can tap into oil pan or back to timing cover. Hope this helps.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
yes
LS1Tech Sponsor
me too, haha. I chose to go to timing cover for drain as it was much easier to get off. You will want to pull whatever you tap so you do not get metal shavings in. Oil pan is a pain to remove so i chose timing cover. However some have tapped on the car without problems but you always run the risk. Oil block is a breeze to get off for feed. The drain is a little more of a pain. Hope this helps Also, steel braided or hydraulic lines seem to be a good choice for the line, some use heater hose as well but not too sure on which is best, but steel braided would get very pricey. I have -4an hyudraulic 2 ply 5 layer for feed and 5/8 heater hose for drain atm, looking to switch to hydraulic however, just need to find some.
__________________
LS1Tech Sponsor
a picture's worth a thousand words right? Here ya go.
In this pic you can see the lines off of the turbos, one runs behind trans cooler to the right, other off to right. (I have a scavenge pump due to low turbos and the pump is located over on right side, why they are running over there)
hoses off turbos going to pump
pump
off turbo
off other turbo
feed going to one turbo, and crossing over to other
oil block (tap into that spout for feed)
timing cover tapped for drain
feed again Tee'ing into one turbo and crossing over to other
other turbo's feed
Hope this helps
pump
off turbo
off other turbo
other turbo's feed
Hope this helps
__________________
