8 rib balancer' available
Old 02-07-2007, 08:19 PM
HUNTER02SS's Avatar
Default 8 rib balancer' available
Is there anybody that makes a 8 rib aftermarket balancer for the f-body.Need to know for my project to decide which way I go with it.Thank's
Old 02-07-2007, 08:23 PM
2000LS1TA's Avatar
ATI Superdampner, be prepaired to pay about 500 with the pin kit.
Old 02-07-2007, 08:34 PM
HUNTER02SS's Avatar
So this actually replaces the stock balancer/pulley?? Basically I am wanting to convert everything to an 8 rib setup instead of the factory 6.
Old 02-07-2007, 09:19 PM
Jake@EPP's Avatar
The stock balancer is replaced by the ATI unit. The lower pulley from ATI procharger is bolted onto the new balancer via 3 bolts.
The crank pulley you can get in a under drive 10% or normal.
This is for the F-body's
The vettes have a single balancer for everything. For there conversion, i would recommend the Innovators West balancer which is a over driver unit to reduce belt-slip uptop.
Old 02-07-2007, 09:34 PM
HUNTER02SS's Avatar
What I am wanting to do is keep the accesories the same as stock on my camaro but want to upgrade to the 8 rib.I am not wanting to put the blower pulley on the crank.
Old 02-07-2007, 09:59 PM
dlandsvZ28's Avatar
I don't think you will want to use the stock one unless you pin it. It will slip. Is the stock one even up to the task of withstanding the extreme pressures applied to it if you were to go to 15 lbs of boost? The ATI will and you will need to pin it too.
Don't be confused by Jake's response which is correct - ATI refers to two different companies as he refers to them in his response.
Jake can correct if this is wrong but the reason the ATI 8 rib is removeable is to allow different pulley combinations to adjust boost.
ATI ( a different company than ATI (Accessible Technologies) makes the crank pulley. ATI (Accessible Technologies) makes the 8 rib pulley.
Old 02-07-2007, 10:39 PM
Tom@SpeedInc's Avatar
ATI 917242 is p/n for Fbody Balancer, you can specify this to be 8 rib if you wish, otherwise it will have std. 6 rib for incoperating the ATI procharger blower pulley to it.
Old 02-08-2007, 08:22 AM
HUNTER02SS's Avatar
Thank You, That is what I was looking for.
Old 02-09-2007, 08:25 PM
clone's Avatar
pm sent
