water cooled?
Typhoons and Syclones were "wet" cooled.. the turbo is a Mitsubishi 16G.. i used to have 2 typhoons but for some reason right now i cant seem to remember the coolant route from the radiator to the turbo..
go to www.syty.net and search around on there for the engine schematic
most turbo systems should be water cooled. the turbo will have an inlet and outlet seperate from the oil side. you just have to find a way to run the water through the turbo. my eclipse had hard lines that were used to do this. it helps prolong the life the turbo and bearings by keeping it cooler. that is one thing i dont like about the sts kits. they do not use water to cool the turbo. well none of the setups i have seen did.
i know the ones to the turbo are metal braided.. but i just cant remember where they join up with at the radiator.. im thinking it was at the bottom from a preformed metal line tube.. and it goes back to the top driverside via same type of tube.. i'll look around in my garage for my service manuals to the typhoon... at least it will give you some idea..
i always thought they were TD06-17c turbos ...
yes wet turbos dont need turbo timers either... if you are just running the oil.. you really should have a turbo timer OR.. do it yourself by sitting idle for about a minute for the oil to cool.. prolong bearing life.
i would not go as far to say they do not NEED turbo timers just because you have a water cooled turbo. have you ever popped you hood and watched how long that turbine housing (and most of the manifold) glows for after a few hard runs or just some mild street driving?
Originally Posted by otherwhitemeat
most race turbos don't run water through them, but i believe you can just splice into your heater hoses.
diffrent in street use thats why all OEM stuff is water cooled and has been for years!
i would still let the turbo cool down after a hard run, either with a turbo timer (dont like them) or by taking the last mile or so nice and steady
thanks Chris.
I believe all the IHI Mitsu turbos of that family are water cooled. WRXs for example use td04s and td05s from the factory and upgrade to 16s and junk.
The coolant lines are rubber hose on barb fittings into banjo bolts though, you do not have to use braided stainless.
lo_jack your right on the Mitsu turbos. def all watercooled. no dout the scooby turbos will be to!
also i heard the otherday the TTI offer water cooled turbos for their vette kit at a no cost extra!
thanks Chris.
thanks Chris.
Heres Inspector 12's speed inc water cooled setup
https://ls1tech.com/forums/attachmen...chmentid=84570
