got my cam for my 408, GT47-88 build
Old 02-23-2007, 08:57 AM
TINKRD's Avatar
Default got my cam for my 408, GT47-88 build
i called up ls1speed and told them all the specs on the build and this is the cam they spec'd out for me.
236/236 578/578 112.5 lsa
i know there are always threads asking what FI cam to go with.
hopefully this one will work out for me.
Old 02-23-2007, 10:32 AM
Juiced's Avatar
Who specd the cam and what size and flange/ AR housing are you using......
you might see some nasty reversion with that tight an lsa and a big single.... backpressure is a power killer.
Old 02-23-2007, 11:02 AM
TINKRD's Avatar
Jim from speedinc spec'd the cam
t6 flange .96 AR
i dont know didly squat when it comes to valve events. i gave them all the specs on the motor setup and this is what they gave me.
Old 02-23-2007, 11:57 AM
LS1Tech Sponsor
Slowhawk's Avatar
The Cam will work out good with that setup.Enjoy.
Old 02-23-2007, 12:10 PM
gnx7's Avatar
236/236 should provide great driveability with 408ci and make gobs of power.
Old 02-23-2007, 12:12 PM
StingrayCrazy's Avatar
I'm building an iron 364 L76 using a hybrid TV81/71 with a .96ar T6 housing. I'm going with the 224/224 .581 .581 on a 112LSA. 11 degrees of overlap with your 408 should work ok so long as backpressure stays low with a big wastegate.
Frank
Old 02-23-2007, 12:14 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Jim spec'd my cam too, enjoy!
Old 02-23-2007, 01:39 PM
TINKRD's Avatar
sweet and sweet.
Old 02-23-2007, 01:46 PM
SuperZ's Avatar
If it was specd at speed inc then its right.
Old 02-23-2007, 02:05 PM
Bryan @ Speed Inc.'s Avatar
i'd have to agree.
everyone thought they were crazy when they put a 236/242 112lsa (if i remember correctly) cam in their turbo shop car. "that's too tight of an lsa for a turbo motor." blah blah blah
car ran 8's w/ a relatively small hydrualic cam. i'd say Jim knows what he's doing.
Old 02-23-2007, 07:29 PM
SSilverSSurfer's Avatar
i went with their TU1 cam(225/225 .581/.581 113lsa) still gathering parts but im sure its gonna do good. 76 here no 88 though
