Which coil packs for best spark(turbo app)
Old 02-23-2007, 02:15 PM
7 Second Club
Phil99vette's Avatar
Default Which coil packs for best spark(turbo app)
Are the truck coil packs the best ones to use or are the LS2/7 coil better for my turbo car?
Phil
Old 02-23-2007, 02:35 PM
Navy David SS's Avatar
Run my stock 98 SS LS1 coils. No problems
David
Old 02-23-2007, 03:25 PM
kp
kp's Avatar
I'm still on my original 98 coils as well, some guys use the truck coils and one is better then the other (2 different truck coils) from what I understand - I try not to fix what isnt broke
Old 02-23-2007, 03:49 PM
andereck's Avatar
19005218 truck coils are capable of 2500+ hp on methanol with the proper dwell control.
Old 02-23-2007, 03:56 PM
ABeasst's Avatar
that part number doesnt work.
Old 02-23-2007, 04:57 PM
andereck's Avatar
You didn't try very hard.
Old 02-23-2007, 05:05 PM
7 Second Club
Ok, thats no biggie. What do you need to do to the dwell control?
Phil
Old 02-23-2007, 05:14 PM
ABeasst's Avatar
I checked GMpartsdirect.
EDIT: I found them on rockauto.
Old 02-23-2007, 05:26 PM
black98ws6ta's Avatar
Phil
Dwell would be controlled by the engine management. I assume bs3 in your case?
Old 02-23-2007, 05:51 PM
andereck's Avatar
Here's an application of the above coils with a Kell ecu doing dwell control.
Attached Thumbnails Which coil packs for best spark(turbo app)-mark_micke_methanol1.jpg
Old 02-23-2007, 06:23 PM
motorbuilt's Avatar
What do you do with dwell control? Ive never needed to mess with that on anything. (I have BS3)
Old 02-23-2007, 06:25 PM
7 Second Club
Yeah, I know its a programmed value in the BS3 and factory PCM, what do you set the settings @?
Phil
Old 02-24-2007, 12:39 PM
BOONE's Avatar
I have the Mitsubishi truck coils part #12558693 which is better than Delphi, and you need bracket part # 12569188, you will need the wiring also, part # appears to be on a bar code is #208059. And Speed Inc has the proper Msd wires for this. This is for stock valve covers.
Old 02-24-2007, 12:44 PM
Black Plague's Avatar
Get some MSD's with that tax money
Old 02-24-2007, 01:04 PM
BOONE's Avatar
Unless something has changed that I have not heard about, getting msd coils would be flushing money down the toilet compared to truck coils, or even stockers. IMO. Not trying to be a smart *** ,so don't take offence please. Just info I read some while back from some people that I well respect. As well as what andereck has just said, that is probably more up to date than my info. Boone
Old 02-24-2007, 01:08 PM
dixonk's Avatar
MSD coil packs are definetly a waste of money!
Old 02-24-2007, 03:22 PM
TTAWD's Avatar
I picked up a set on ebay for my sbc running "LS1 BS3" the part # is 12573190.
The local GM dealer sead they fit 06 Z06 trucks GTO's right down to V6 Malibo's.
Are these any good?
Old 02-24-2007, 04:17 PM
HAMRHEAD's Avatar
I use the truck coils.
Old 07-02-2008, 09:39 PM
Jimmy P's Avatar
For those of you with the truck coils (12558693) what did you do about the harness? We have the Mitsubishi coils and we are using BS3 and they wont plug into each other.
Old 07-03-2008, 08:34 AM
camarols1's Avatar
You can use two of the GM harnesses, part # 89017477
Quick Reply: Which coil packs for best spark(turbo app)
