F Body intercooled twin turbo system - preliminary pricing $5495 inc free delvery
#341
Originally Posted by Inspector12
Wasn't grouping you guys with anyone. Just letting the few that were debating what MM had said because it had merrit to be sckepical of things until it arrives because he was speaking from a bad experience he had in a simular sittuation (Incon). And I am aware of your other kits that have been delivered and they look great. I have no real doughts, but was letting the few that couldn't understand why anyone would have any reservations and the reasons behind them etc... Can't wait to see some results from your kits.
Peter
http://www.ls1gto.com/forums/showthread.php?t=140687
http://www.ls1gto.com/forums/showthread.php?t=145572
http://www.ls1gto.com/forums/showthr...64#post2407364
http://www.ls1gto.com/forums/showthread.php?t=145482
http://www.ls1gto.com/forums/showthread.php?t=143297
http://www.ls1gto.com/forums/showthread.php?t=144863
http://www.ls1gto.com/forums/showthread.php?t=141156
http://www.ls1gto.com/forums/showthread.php?t=144812
http://www.ls1gto.com/forums/showthread.php?t=144705
http://www.ls1gto.com/forums/showthread.php?t=141672
#343
Originally Posted by GrnDragon
My only concern with the kit is if the Turbos really will be efficient on a 427ci engine to be able to run about 12-15psi. From reading the other TT companies thread they seem to think that the turbos being used on this kit will not be big enough to support the claimed 900 RWHP.
I know this is probably a he said she said kind of situation, but I have read it a couple other times that the turbos included in this kit aren't that big. I know Peter gave us the specs for the turbos, but I'm new to the turbo scene and all those numbers didn't mean anything to me (I need to see actual data that shows what the turbos can do on a Large CI motor). That is my only reservation is putting money down on a system that I haven't seen any results for to know if it will support my NEEDS...
Also, was there ever a price given for the fuel system?
Thanks,
Peter
#344
Hi Guys, I just coaxed an engineering diagram (actual engineering model) of the F body twin turbo left hand side exhaust manifold from my friend in our engineering department. As you can see the F body twin turbo project is progressing very quickly and the production shell core/shell mould exhaust manifold tooling will be completed by mid May if our tool maker meets his quoted lead time, enjoy!
Peter
Peter
#345
Peter
Peter
Nice pictrue by the way! What connects the manifold to the turbo? I imagained the manifold extending further down connecting directly to the turbo
#346
Originally Posted by 2002 Trans Am
No "if" I think you mean "when"
Peter
#347
Correct, the manifold tooling had better be finished by the due date.
The turbo bolts directly to the flange that you see in the picture.............this way the turbos are above oil pan level and the turbos don't require the extra complexity of a scavenge pump to return the turbo lubricating oil to the engine.
Peter
Peter
I'm not a fan of scavenge pumps either. Another part to possibly fail and take out a ton of **** on it's way. Plus it looks cool as hell to drill and tap the oil pan with AN fittings and huge lines
#348
Sounds good, if it fits it fits is all I care.
Peter
#349
BTW your manifolds look awefully similar to the Speed Inc TT manifolds (thats a good thing)
Their kit uses
GT35R or GT35R ball bearing turbochargers
PT67 P-trim ball bearing turbochargers
PT300-6152 61mm standard bearing turbochargers
How do these turbos compare to the turbos your kit will be offering?
Their kit uses
#350
The F body twin turbo system will fit like a hand made tailored suit.................that's for sure.
Peter
Peter
#351
Peter
Peter
#353
Thanks for addressing my concern Peter, this kit just sounds like it may be perfect for my use in a street car with crazy power and easy/fun to drive.
I was looking at you website for the C5 kit and I noticed you sell a complete dual 3" SS exhaust system to go with your kit for the C5's, will there be any thought to offering the same thing for the Fbodys (BMR offers a panhard bar relocation kit to accommodate a dual 3" exhaust system)? I am VERY interested in the TT kit and if you decide to make them the fuel system and full exhaust system.
#356
Peter
#357
Coal Mining Director
I have not seen that exhaust manifold (do you have a pic) though once you fit the K member our engineers and prototype techs tell me that's there's only really one practical position for the twin turbochargers.............we all have to work around the same physical space available for the turbochargers.
Peter
Peter
#358
Peter
Peter
Peter,
I'll bet ya an Australian Coke the passenger side manifold plus turbo can not be installed as one assembly.
#360
Originally Posted by onfire
Thanks,
Peter
