My 91mm Turbo Project So Far...
This is my set up so far minus the wastegate location, but it will probably go by the fuse box. I have a real 5in downpipe through the K-frame and I'm going to step down to 4in all the way out the back.
It was a PT-88 before and it was in approximately the same location. I had to cut the frame to make the new turbo fit. And the radiator is the same one I used before and I didn't have to move that again. I made all of the hot piping (which I am still working on), but used part of an SLP header on the passenger side. All of the hot piping needs to be finish welded and cleaned up. I will be ceramic coating the pipes when they are done and looking good.
I got a Griffin front-mount intercooler with aluminum piping throughout. T56 Rebuilds currently has my 6-speed to do a face-plated G-Force tranny and somehow putting an SFI bellhousing on it.
Here's some pics. Enjoy!
Originally Posted by MIGHTYMOUSE
how fast did you go with the 88? i assume you maxed out it's capability?
Originally Posted by otherwhitemeat
im more of a street racer,.....so i have no numbers for you. but yes i didmax it out....and i sprayed a 150hp shot too. all with race gas and a aggressive tune
i love hearing about guys with BIG hp that race on the street(but carefully ) i hate it when everybody ask's what does it run?...... i just reply with "circles around your car"
goodlooking kit my friend, i wish i knew how to weld, i would build my own kit
having an 88mm on my 6spd car i know how the lag is, and i can only imagine how much worse a large frame will be. i assume the guy is over 1100 at the wheels to be making the sacrifice.
i doubt it
then what would be the point of going bigger? lol, unless you're having traction issues from not enough lag.
im curious why an 88mm wouldn't be sufficient on the street. op, what are your cubes?
It will be an interesting experiment if only for the BB turbo !
When we fitted a ITS T70 to a 2.3 litre Subaru, we thought it have terrible lag...
It was far from it. Spool was excellent. The fun was cut short with a dropped valve tho
BB turbos should be used more often. They defo work well on smaller engines.
Looks nice Jesse, were you running two fuel tanks or was that your buddy?
so lets say im going down the road on pump gas..... now a see something that might be fast coming up on me, so what i do is toggle switch off street pump and toggle on race pump.....i then immediately reach to my 2 turn valves and switch the race race to return to the race gas tank so i don't waste it ...........from their drop gears...brake boost it and go!
and to go back 2 street gas just flick a switch and turn a valve now your back running 92.
hmm, well i don't see how, but hopefully some way you will be able to take advantage of it.
i reccomend the 325/50/15 mt dr for any hope in at least 3rd gear on the street...assuming it spools
i'd like to know more about your fuel set up too.
full spool at 5000rpm ???? IMO thats pretty bad. And thats your old setup ? Unless you had at least 8000rpm available, that doesnt sound nice at all.
