Turbo setup o2 before or after
Old 03-04-2007, 02:31 PM
flippincamaro's Avatar
Default Turbo setup o2 before or after
Okay my truck has been single turbo then twin now going back big single, My ? is do I need to stick the o2s right after my headers before the turbo on each side or in my downpipe after the turbo? I have been told the heat before the turbo will screw them up, So I have always ran them after the turbo in the downpipe, But where should they go and why? Thanks for any help
Old 03-04-2007, 04:49 PM
otherwhitemeat's Avatar
after.....and you want it to be mounted around 8 to 12 inchs out. i don't know the tech info though.
Old 03-04-2007, 05:23 PM
cablebandit's Avatar
my incons had the o2s mounted in the manifold before the turbos. The pressure at wot does skew the readings but that is not an issue at idle/part throttle. Of course, you arent using them at wot. Now the wideband o2 does need to be after the turbo.
Old 03-04-2007, 06:26 PM
Old Geezer's Avatar
Absolutely right on the problems B4 the turbo.
Excessive heat, and gas pressure will affect the life, and accuracy of the sensor[s].
Best shot is in the DP, and at least a foot away from the turbo...
Old 03-05-2007, 02:08 AM
Thanks guys, That is where it is all going again then is after in the downpipe with the wideband, Thanks alot
Old 03-05-2007, 06:53 AM
Old Geezer's Avatar
Lightbulb Also...
When you weld in the bung, be sure the tip of the sensor is pointed downward. I like to position the bung between 10 and 2 o'clock. This position will prevent moisture from collecting in the protective shell, and ruining the sensor.
Old 03-05-2007, 09:00 AM
Ping King's Avatar
my o2s are mounted before the turbo. My WB is mounted after. Ive heard many different theories on how they should be mounted. I see how they can become all fugged up if you mount them before.
Several OEM cars, including my WRX have the O2 mounted before the turbo.
Old 03-05-2007, 10:28 AM
LS1TECH Sponsor
DrTurbo's Avatar
Narrow band O2's are before the turbo, widebands are after the turbo.
Quick Reply: Turbo setup o2 before or after
