Spun Rod Bearing - Thinking Boost - Questions!
Old 03-06-2007, 08:03 PM
nomorews6's Avatar
Default Spun Rod Bearing - Thinking Boost - Questions!
I have 62cc 2.5r 5.3 tsp prc heads, ported FAST 90/90, long tube headers and a 230/234 595/585 cam. How well would my setup work with boost? I am thinking a rear mount turbo setup while putting in forged pistons & rods. What exactly should I get, and what kind of power can I expect? Advice greatly appreciated!
Old 03-06-2007, 08:29 PM
TA TECH's Avatar
Not very well forced induction likes lower comp ratios!especially turbo's!Like an example 9.5to1
Old 03-07-2007, 06:46 AM
BLOWNBLUEZ06's Avatar
Maybe you can get away with higher static compression by lowering your dynamic compression with a cam. Thoughts anyone?
Old 03-10-2007, 06:14 AM
EPP
EPP's Avatar
I'd go with an ATI ProCharger with your compression ratio, as centrifical superchargers like a higher compression ratio than turbos can tolerate. Bob
