13 psi, 408, pt88, 91 octane still few issues dyno sheet
Still having a little issue. Thinking maybe the coils being located and close together maybe we re having some ignition problems. Maybe going to truck coils on a valve cover bracket may help???????
Here is the dyno with the tq and the Rpm drops from the pickup on the dyno.
Made 823 HP and 838 TQ
6 Second Club Moderator
Same thing happened to me, truck coils solved the problem . Good luck!
That is what I am hoping. Already played with the dwell. next stop new intercooler and then some c-16 high boost numbers (if the stock rear holds).
I am on a 6 spd trans and 9-1 comp.
it was just under 700 uncorrected like 68x if i remember right.
I am the person who is testing stuff on our kit. Tested the vic jr vs the ls6, ls6 is better manifold IMO. The vic jr loses a little from 4200 to 5200 and both nailfolds make the same peak hp numbers. There is another post where the results are posted. The Victor Jr made more peak # uncorrected but the DA was better that day. Corrected vs Corrected the ls6 wins.
Will be testing the xspower ebay cooler vs a nice huge precision core with custom end tanks. Then seeing how much the 9 in 350 gear spool moser loses over a bone stock 10 bolt.
LS1Tech Co-Founder
Wow the dyno corrected from 680rwhp to 820rwhp for altitude, dang.
I'm running truck coils and MSD truck wires on stock 99 valve covers, I actually like the stock setup cuz the wires are short and don't get burned.
http://psj.ls1tech.com/gallery/main....d=10&g2_page=5
