Superman09's Twin Turbo Build Thread Part 2
Old 03-10-2007, 10:59 PM
LS1Tech Sponsor
Superman09's Avatar
Default Superman09's Twin Turbo Build Thread Part 2
Well time for part 2. Car is pretty much done. As is sits now, only the y pipe needs to be completed. It is nearly done, just ran out of bends so i had to order some more, should be here Mon. I changed my PCV set up and it is ran like i had it set up in the MSPaint pic in last thread with a catch can. Few facts... getting too much oil, its being pushed threw and is messy, lol. Idle vacuum of 24", can hear turbo noise at 800 rpm and she gets going at 1000 pretty good. Have to track down fan issue, for some reason they wont turn on, but when we grounded it's relay they turned on so its something stupid like a ground off or something.
Some questions...
-Too much oil, where do i start? Have access to nitrous jets, do i place one in the feed line right out of the oil block spout or up near first turbo (set up runs to drivers side turbo and crosses over to pass side). Where do i put it and what should i drill it out to?
-Is 24" of vacuum good at idle? Seems like a lot but then again its twins on stock cam, low idle of 500 rpms.
So here are some new pics of the PCV, progress of Y pipe, etc.
A New Video at bottom! Still open DPs, can hear turbos start at about 800 rpms and can really hear them at 1000. Didnt go over 1000 rpms, but you can hear them. Also see the vacuum, Fuel pressure of over 60 at idle, and my tranny cool as a cucumber.
Old PCV crap
New PCV
Catch Can
Another
Tee
Y-Pipe
Another
Another
As She sits
http://video.ls1tech.com/video/35d64...ed0187e93e.htm
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 03-10-2007, 11:13 PM
RooRnZ28's Avatar
awesome!!! now take some more pcv pics! pleeeeeeasee
Old 03-10-2007, 11:17 PM
LS1Tech Sponsor
Superman09's Avatar
Well its hard since its all mostly way back under the cowl. However...
One line runs from back port in Drivers Side Valvecover over into 1 part of the tee. A line from the back port of pass side VC goes to another part of the tee, a line from the last part of the tee runs to the catch can. I capped off the front pass side VC port, TB, and Intake. Have breathers on Catch Can and oil fill.
__________________
Old 03-11-2007, 12:29 AM
Dragframe's Avatar
lol.. part two.... I thought it was pretty funny when the last one was closed because "no one was going to read through all of it" and i jsut finished reading it from post 1 to the end! lol...
Looks good. I wish i had your car.... but im "stuck" with a big single on a LT1... lol
Old 03-11-2007, 10:15 AM
LS1Tech Sponsor
Superman09's Avatar
lol, "stuck", im sure your car moves out and would wax me all day, haha. Anyways, anyone have any help for my restrictor question?
__________________
Old 03-11-2007, 02:42 PM
LS1Tech Sponsor
Superman09's Avatar
Anyone?
__________________
Old 03-11-2007, 02:47 PM
Dragframe's Avatar
lol.. i wish... coming together likes yours... plus what you ahve going for you is... ls1.. lol... its like cheating!
Pistons and hardware would make 500 hp attainable in my car...
but i just plan on doing rods too
I really do love your car... plus twins
My car is just stock lookin. lol
http://myspace-586.vo.llnwd.net/0115...54257586_l.jpg
http://i13.photobucket.com/albums/a2...1011061428.jpg
http://i13.photobucket.com/albums/a2...1117061733.jpg
This was the build of the hotside
https://ls1tech.com/forums/lt1-lt4-modifications/610502-turbo-lt1-figured-you-guys-would-like-see-56k-beware.html
Old 03-11-2007, 02:54 PM
LS1Tech Sponsor
Superman09's Avatar
haha nice second pic. Very sleeper!
Anyone have any help about restrictors, where i should place it, what i should drill it out to, etc.
__________________
Old 03-11-2007, 02:59 PM
Dragframe's Avatar
For the oil into the turbos? Just get a normal -3 fitting by thread... cut the angled part off the fitting... and put your nitrous jet in there for a restricter. The nitrous jet makes the angled part you cut off...
Thred the thread part ofthe fitting into turbo feed and drop your jet in and screw your line in.
Old 03-11-2007, 03:00 PM
LS1Tech Sponsor
Superman09's Avatar
ok, is that the only way to do it? And do i need to drill the jet out? if so, to what? Thanks man!
__________________
Old 03-11-2007, 03:02 PM
Dragframe's Avatar
You just can use different size jets... dont have to dril out anything
But i will have to do a lil searchin on what jet to use...
Old 03-11-2007, 03:20 PM
Dragframe's Avatar
it may be a pain in the ***... but put a T into the turbo... then your an fitting cut to take a nitrous jet... then screw your oil line on.... off the T run a oil pressure gauge.
Restrict it down till the turbo only gets 40psi to it. You should only have to T off one turbo because you probably will use the same jet in both sides... once you get it to where the turbo is getting 40psi... take out the T and your good.
I can't find what people are using so i figured i would tell ya how to figure it out. lol
Old 03-11-2007, 10:09 PM
Eric Bazan's Avatar
Why dont you get a Function7 oil feed flange with a built in regulator? Pretty nice piece for about $18.00.
Eric
Old 03-11-2007, 10:13 PM
LS1Tech Sponsor
Superman09's Avatar
Well as stated above, i have access to nitrous jets. At this point in my build, as most of you are aware, these $50 projects are really pissing me off so i dont want to have to spend $50 on restrictors (2 turbos) when i can use nitrous jets that are laying around. However those do look nice. I think im going to try to lower my scavenge pump more so it doesnt have to suck as hard, and fiddle with a nitrous jet in the feed line. See how this goes.
__________________
Old 03-12-2007, 10:43 AM
obZidian's Avatar
whats up sup?! Another on huh? Dude, it seems like you got it with the nitrous jets. Also, that function 7 seems like a good produce and not expensive... either way, your almost there mang! Just stay focused and get that T/A running!
Old 03-12-2007, 11:30 AM
99Z28LS1's Avatar
what a sick car my friend. looks very clean and cant wait to see what kinda numbers she puts down when she's done
Old 03-12-2007, 06:28 PM
HUNTER02SS's Avatar
Look's good,I hope mine go's as well as your's has.
Old 03-12-2007, 06:32 PM
01ramair500hp's Avatar
now that you are done with it.. i will offer you a deal you cant refuse. i will trade car for car.. so then you can start all over again!
Old 03-12-2007, 06:47 PM
LS1Tech Sponsor
Superman09's Avatar
haha, yours is broken... no deal! Thanks for all the positive compliments!
I called up Rich at W2W today who will be tuning the car. I was planning on running my computer down to him with a spec sheet for him to give me a quick rich tune so i can drive down on the bigger injectors, but he said i'd probably be just as safe keeping stock injectors in and stock tune and just babying it since its 95% highway driving and i dont have any other motor mods. He said he'll just throw my injectors in on the dyno and we'll be good. He said he is open next week!
__________________
Old 03-12-2007, 06:54 PM
Navy David SS's Avatar
Get that damn thing tuned and to the track. Enough of this bench racing. Can't wait to see what it will do. At least you're near a great tuner. IMO beg, borrow, steal a trailer. There's no reason to take any chance on hurting it. Good luck.
David
Quick Reply: Superman09's Twin Turbo Build Thread Part 2
