Official STS help thread
I thought it would be a good idea to have a thread just for the STS kit. I know that there's all sorts of questions and ideas to help these kits work better so I thought I would make an official thread just for it.
Anyone feel free to post any questions you have and hopefully my fellow STS brothers and my self can help out
also, what are sts guys doing for their pcv setups? i've seen countless threads on pcv, but no one shows their setup w/ an sts kit. and i dont really like the idea of a breather on the oil fill cap, so any alternatives?
John
1 Post
Here's a couple pics. All I have for now, as the car's in Seattle and I'm in Iraq
Here's the PCV lines from the valve cover and the STS bypass switch
From the valve cover it runs to an AMW catchcan. The can seems to dissipate the crankcase pressure. Sure you could add a breather to the catchcan, but I haven't had a need for this. From the can it runs back to the STS pressure switch and then into the PCV valve.
Here's a pic of the Catchcan. It's located next to the radiator by the AIR pump breather. The lines run along the top of the radiator to and from the can.
Hope this helps.
Originally Posted by GR33N GoblinM6
here is the biggest help and best advice i can give on STS..
DONT BUY IT UNLESS YOU LIKE PROBLEMS AND HEADACHES...
and thats my opinion..
actually its not useless.. some people really dont know a thing about them.. just hear they are bolt on and go... but find out there is a A LOT more to it... so no its not useless..
every system has a catch to them, no matter what you buy,sts prolly aint the best but im willing to try it,and after im done installing it if you wanna put ur money where ur mouth is ill for sure show you they arent that bad of a system
If the product is presented the right way and the customer knows pros and cons as well as ALL necessary parts, then the only other issue is someone that can install everything to work as designed. IMO, 90% of the issues are due to the installer.
and to GR33N GoblinM6, this is an STS thread only, if you want to flame someone, go to seatsstayup.com
Hey now, why do you have to pick on a poor bolt on 98 car. Why don't you show me its not that bad of a system.
i see in the picture above and I don't mean to change the subject, but where in the hell do yall find these upper radiator supports? i can only find the one that BMR makes...and I don't like it cuz it has two humps.... lol. I want the one hump at the radiator and then smooth to the body like above.. cuz I want to paint on a Black bird centered on it
oh yea im pretty sure me and you will be running each other about a thousand times this summer,hopefully my rearend will hold up
most likely ...back and forth, mod after mod. Should be interesting. After all the trash talking has been done I can't wait to see how that T/A sounds. Im sure it will move good.
I know you and Al don't like Livernois, but you may have a thing or 2 to watch out for this summer.
Your rear end should hold up. Take it easy on the 1.4 60's.
nothing really against livernois just had a couple buddies get screwed by them,so we deside to take are business somewhere else no bad blood, yea 1.4 60's more like gonna be 2.4 60's,but cant wait till summer
