manual boost comtroller ????? with T.T.
ok i am going to put a homemade boost controller on my car this week, my ? is with twi turbos can i use just one controller, or do i have to use to seperate, and control the waste gate seperatly?
or can i came from the turbos into a "T" in to the boost controller, out to a "T" and then out to the Two wast gates????will that work? will they be the same boost levels on both banks???
I would think that it would be more accurate in holding down boost creep (if they are internal gates, Incon style anyway) if you used two MBCs and used less line, or at least one MBC with two WG lines (instead of one).
