O.F.I Turbo kit pics installed
Just thought I would share with you guys a build that we are doing here at Ohio forced inductions for a customer. The car was dropped of on the Jan 21st. The car is a 2000 Trans Am with some really nice ccw rims on it. The customer is getting the 98-02 stainless steel turbo kit with the T-76gts. The kit is also going to be air to water. Some of the other upgrades are going to be....
UMI torque arm
UMI subframes connectors
UMI LCA
Moser 9" with a trutrac and 3.50gears (from Driveline solutions..Thanks)
OFI fuel system
60lb Injectors
3" steel Driveshaft (from driveline solutions)
Comp cam
Speed Inc 370 iron short block
Guages
Rossler stage 3 trans
EBC
Here are some pics of the setup pretty much done besides the pvc setup. Its just wasent installed on the car when the pics were taken. The car was at the dyno this week and made 650rwhp easy with 10 lbs of boost and 12 deg of timing at 4500 rpm. We had to cut it short b/c we were blowing right threw the torque convertor. Have to upgrade more and back to the dyno on friday.
After the install of the kit we also did not have any exhaust leaks. No warped flanges or v-bands. The kit went on and started right up sounding terrific. Also make sure you look at the welds. I have been getting blasted lately on the welding b/c they dont look perfect. I think these welds look really good. There is also no crysteling inside the pipes. I did however have that on 2 GTO kits, but that is all taken care of. Let me know what you all think. Im here to listen to what you have to say.
Thanks joel
UMI torque arm
UMI LCA
OFI fuel system
60lb Injectors
Comp cam
Guages
EBC
Thanks joel
Originally Posted by BAD *** TA WS6
Kit looks awesome. Only thing I don't like is the lower coolant hose touching the header.
Ground clearance is awesome, his car is lowered as well right?
nope...no proplem with burning wires. they do look really close in the pics though. The radiator hose isnt touching the header. It s just really close that is why I wraped it just to be safe. The hose is stainless pipe also.
Senior Member
Id also coat everything along with wrapping. Id be very concerened with the plug wires. Youll have to watch those closely. I have to double shield mine (plug wire boots and then heat reflective tubing over that) to keep from burning them.
It looks good.
Nice car too. What color neons? Bout time somone has ***** to go against the grain. I had purple
It looks good.
Originally Posted by 00TurboT/A
Are you guys having any troubles burning up plug wires????? Its looks pretty close above in the pic. That was just a big downside on a couple of older kits.
REALLY.... thats very hard to believe........ esp. them being that close...
How many miles on the setup??
Any street miles???
Drive the car for a few 75 mile trips and let us know.......
Im with Country Boy on that one..... i have Reg. style headers and i have to make sure mine are placed just right...... ive burned a couple.... none ina while...
Originally Posted by smokinHawk
is all that listed provided by you? looking at the, what i think is the overfill tank next to the fuse box. If so what is the cost of that alone, and what is the capacity?
and what is that fuel cell used for where the battery used to go?
That is the chiller tank for the air to water setup.
Originally Posted by 1INSANEGTO
I still would like to know what was taken care of? You going to pay the bill I am sending you to fix your screw ups?
I also offered to fix your stuff, but never heard back from you. If you have a question email me or call the shop. Please leave Gotv8's thread clean so he can enjoy his thread.
Thanks Joel
kit looks great! I would wrap those plugs on my car though, just for safe keeping. Is that the stock radiator?
Joel, are you thinking of designing a radiator shroud at all to clean that up a bit? Would be sweet!
insanegto: stick to pm's will ya...
