putting a turbo sytem together need help!
Old 03-24-2007, 12:27 PM
THEBRAD's Avatar
Default putting a turbo sytem together need help!
im putting together a turbo system fo my 2000 trans am and i need some help finding the parts and how u guys have done it. im running a garret t4 turbo. i need an intercooler and i need one that actually fits and i dont have to cut huge holes in stuff and where to get it. i need to know where to get an oil pump cause it remote mount, a sandwich plate or something like it for the oil pan and what fuel pump and injectors i should get and oil lines. i also need to know where to get this stuff and if u guys have anything for sale. its a stock motor so i plan on using a dual stage controller and switching between 400 and 500 rwhp. all help would be great
Old 03-24-2007, 12:50 PM
Ping King's Avatar
you can do a FMIC from ebay. You can get a scavenge pump from any of the big speedshops. I actually happen to have a scavenge pump, wasegate, and some random turbo stuff im trying to sell if youre interested.
Old 03-24-2007, 01:06 PM
THEBRAD's Avatar
i have a nitrous kit i want to trade need intercooler and way to install it on trans am keep seeing camaros with intercoolers so would those fit in my car?
Old 03-24-2007, 01:35 PM
CantKeepemhooked's Avatar
http://www.trtturbo.com/LS1FMIC.html
shows a T/A with a FMIC
Old 03-24-2007, 02:17 PM
Boo"SS"t's Avatar
FWIW, you can go to "FOR SALE" section and do a search for the rest of the components that you'll need.
Old 03-24-2007, 05:37 PM
THEBRAD's Avatar
sweet anymore help or parts would be great!
Old 03-27-2007, 09:28 PM
THEBRAD's Avatar
bump!!
Old 03-27-2007, 09:48 PM
Sawzall and Welder Mod
Whistler's Avatar
Spend a few hours with the search, and you'll see what others are doing.
Old 03-28-2007, 09:59 AM
otherwhitemeat's Avatar
If you are only trying to make 500 rwhp.....go n/a with juice! It will be a lighter car with way less problems....
Old 03-28-2007, 10:38 AM
Eatinstang4life's Avatar
not true at all dont do that, I am just finishing up my rear mount set up, no problems so far runs great.
-Get the mocal pump for the scavenge return oil system.
-intank walbro fuel pump
-42lb injectors
-obx fmic (you will either have to remove your bumper support or cut it for sure)
-fuel pressure gauge
-boost gauge
-many little things such as lines, hoses, fittings and such.
just take your time and do one thing at a time. any questions feel free to pm me and ask.
Old 03-28-2007, 10:56 AM
just my opinion, as is yours......it can make more power witha good motor and juice then your kit and will weight less. Plus my car would be easyer to work on!! just a thought
Old 03-28-2007, 07:27 PM
THEBRAD's Avatar
i used to spray the juice hated it! a zex wet 125 shot. couldnt feel the difrence at all. everybody always says its seat of ur pants diffrence they lie lol. so im going turbo!
Old 03-28-2007, 09:11 PM
JAvenger007's Avatar
check into enginegear's pumps instead of mocal. After testing around, the tilton/mocals seem to have a diaphram problem. The enginegear models are stainless shafts, brass bodies, and bronze gear designs. Theyll last.
Old 03-28-2007, 09:29 PM
THEBRAD's Avatar
sweet thanks for the heads up!
Old 03-28-2007, 10:00 PM
THE_SUPRA's Avatar
the guys at TRT really are a great resource. you can get everything you asked for from them at a very reasonable price. i woudl also suggest napa auto parts and summitracing.com for the odds and ends stuff (which you will need)
Old 03-28-2007, 10:03 PM
ZL1Killa's Avatar
check my sig
Old 03-28-2007, 10:35 PM
if you couldn't feel it it wasn't working....period!
Old 03-29-2007, 07:31 AM
trtturbo's Avatar
I have to agree, something was wrong if there wasnt any difference with a 125 shot.
Old 03-29-2007, 07:35 AM
ZL1Killa's Avatar
you must be nuts or the thing wasn't working. I have been in a car that was spraying 125 shot.. and yeh, lets say she got up and went.
but yeh a turbo is nuts. full boost hits and your pushed into the seat. it starts up gradually then bam! in seat... lol
Old 03-29-2007, 04:31 PM
if you've got an ACE hardware nearby then use them for all your fittings. Dont bother with summit and forget homedepot/lowes (their selection sucks). Most of the pumps have 3/8" NPT male or female. Male on the enginegear/reverso pumps.
Ill see if I can find the silicone dealer that i usually use. They sell elbows (for connecting to TB) at great price and most couplers are less than $5 with clamps. Also consider building a homedepot catch can if your tryin to keep things budget. Search will do wonders
