STS turbo Exhaust gasket???
Old 03-26-2007, 04:40 PM
zapp168's Avatar
Default STS turbo Exhaust gasket???
Hi
I have just installed a used STS rear mount on my 98 T/A and was wondering if someone could tell me if there is supposed to be a gasket between where the exhaust mounts to the turbo(4 bolt flange)? And if so where could I get one quickly?
Thanks
And THANK YOU to all who helped me install this without instructions
Old 03-26-2007, 05:26 PM
JD_Z28's Avatar
Yes there is a gasket that goes there. You should check with a local speed shop or turbo shop for it. You could probably build one to.
Old 03-26-2007, 07:11 PM
OreoLt1's Avatar
Like "JD_Z28" said there is definately a thin sheet metal style gasket that should be there. I needed an extra gasket just as you described for another project and called the STS tech line and they sent me out one at no charge although they may charge a minimal price now. Doesn't hurt to try!
Old 03-26-2007, 07:16 PM
crazycat's Avatar
like oreolt1 said, thin metal gasket.
Quick Reply: STS turbo Exhaust gasket???
