ECS meth controller, wideband, liinelock Ashtray Panel
i did the same thing on a friend of mine's car, except i took the ecs controler apart and mounted just the ****, led, and test button on the pannel. and i put a shift light where you put the gauge
Thanks guys.
I like the gauge there, it isn't that big of a deal to look at it there. To be honest the reason I went with the gauge there was bacause I just don't really care for the triple pillars as I already have the fuel pressure gauge and boost gauge on the pillar.
That there is some squared-away top-notch work. I actually like the gauge there; I don't really have much use for mine -- never really look at it when I'm WOT, and the Dynojet wideband has a configurable (AFR/RPM/TPS) external trigger that you can set up to sound an audible alarm. Or shiftlight, if you prefer.
Originally Posted by obZidian
sweet... off topic though, can you get that gauge with a black rim instead of the silver ring?
