Finally crossed the 130 mph barrier, too bad the 60' sucks
Best for me was 10.782 @ 128.29, 1.718 60'
Still couldn't build boost on the line Have to work on that, can't keep the exhaust hot enough to spool it well with my tight converter. New completely insulated exhaust system should end up fixing that.
Fastest MPH of the night was 11.195 @ 131.51, 1.911 60' (that is a 5psi launch lol) Happy that I can finally cross the 130mph barrier into a head wind, now I just need to pull together the launch and I'll hopefully go low 10's
Congrats!! awesome dude! i'm grabbing my moser 9" and then i will be hitting the track... still won't be using sticky tires but it will be a blast. I gotta wonder how long my stock clutch will last. once it goes i will be upgrading the tranny and clutch (textralia oz700 series) and the tranny from t-56rebuilds.... and yes, doing it all myself
Originally Posted by cablebandit
do you have a tbrake?
5psi = 1.9 60' 6psi = 1.8 60', 10psi = 1.5x 60'
Going to have all my exhaust redone and fully insulated from the manifold to the turbo, that will probably solve the issue, iff not I'll just use No Other Solution
How much does a 2 step help on a trans brake car?
i bet it will add 3-4 psi to what you already have. how is the tune when you are on the brake? lots of timing ?
At 0psi it stalls to 3000 rpms At 6psi the converter stalls to 3500 rpms, at 10psi it stalls to 4000 rpms. I just can't get over the hump to run away boost land.
Main problem is heat since my turbo is eleventy billion feet away from the motor. The car is working pretty good power wise after the launch since I'm able to trap 103+ in the 1/8 mile and 130+ in the 1/4 (had a head wind too last night). Judging by past slips I should go 10.3 @ 132 if I could launch with a 1.60 60'.
The other solution to this issue would be to put some nicer heads on the car to so it makes more power at lower boost. I'm on completely stock LQ9 heads with springs of course. I ran a max of 17psi last night. Going from 15psi to 17 psi and pulling 1 degree of timing (had 2 degrees of KR) on the top end netted me 3 MPH. I think heads would really help my car out overall with spooling.
Mr_president went 10.22 @ 134.9 with a 1.48 60ft........ON ONLY 8 PSI.
You seem to have similar set-ups. I would expect to go at least high 9s on 15psi.
Originally Posted by ninetres
SOmthing isn't rigth with your ride I feel.
I'll run in the low 10's once I sort my car out, but it takes more boost here, I also am running stock heads and have a heavy car. If I ran 8psi I'd probably run 11.9 @ 118mph LOL
which stock heads?
Originally Posted by coop5885
which stock heads?
I'm like the sanford and son of turbo cars.
Congrads on the mph Jeremy! That kicks ***! Hey, give me a call, I will be in vegas over Easter(sat late night through monday), maybe we can grab lunch or something. I no longer have the Z28 though.
DarkblueTA, sorry man, I'm in Hong Kong right now and will be until the 13th, otherwise I'd love to. On another note though, I am huge over here LOL
67Firebird455, I'm not sure what kind of power it's making, but I like it I'm axious to see how much of a difference having the exhaust fully insulated from manifold to turbo makes. Right now just the y-pipe and I-pipe are done. It's not up to the manifolds due to the hollow cats. Should also have a 50 shot on it soon to aid in staging faster...
