PCV smokin, coolant N oil - LS1TECH
Thread Tools Search this Thread
Old 03-29-2007, 06:55 PM   #1
Default PCV smokin, coolant N oil
So what would you assume if your PCV breather mod was smoking?
There is coolant in the oil
What all could let coolant into the oil?
1) head gasket
2) upper / lower intakes & TB gasket
3) front (timing) cover gasket
What else?
thanks
ezrollin is offline   Reply With Quote
Old 03-29-2007, 08:36 PM   #2
TT-TECH Veteran
Inspector12's Avatar
Only one of the above is the head gaskets. I am thinking of a cracked head if not that. Hope that helps.
Inspector12 is offline   Reply With Quote
Old 04-01-2007, 01:52 AM   #3
Turbo T/A's Avatar
Mine did the same thing. It smoked out of my vented catch can & I found coolant in the oil. I tore the motor apart and among other things it was blown out rings & a cracked cylinder wall. I know that doesn't make you feel any better. Best of luck to ya!!
Turbo T/A is offline   Reply With Quote
Old 04-01-2007, 07:44 PM   #4
dschmittie1's Avatar
yeah only think that would let coolant get in the oil would be head gaskets, cracked heads, or cracked block. The intake doesn't have any coolant running through it and front cover doesn't either
dschmittie1 is offline   Reply With Quote
Old 04-01-2007, 07:45 PM   #5
Also coolant in the oil isn't good the the bearings at all. I hope it wasn't like that for too long.
Old 04-02-2007, 06:21 PM   #6
yea, i'm retarded for forgetting to mention
cracked block
cracked heads
cracked front (timing) cover
cracked intake
sorry, this is NOT an LS1
thanks for advice!!
Related Topics
Thread Thread Starter Forum Replies Last Post
Coolant seeping out of the oil pan gasket area shhwing Generation III Internal Engine 22 01-30-2017 05:57 PM
Oil In Coolant Reservior Crimsonnaire General Maintenance & Repairs 16 05-12-2008 10:59 AM
Coolant in the oil.. Fixable? 95camaro3800 LT1-LT4 Modifications 6 03-10-2008 09:44 AM
Occasional smoking... and what color does synthetic burn? DuronClocker Generation III Internal Engine 2 09-05-2006 11:56 AM
Blown head gasket or condensation? z28hokie Generation III Internal Engine 6 02-28-2004 09:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
