Are any turbo cars NOT running oil coolers?
Old 03-30-2007, 03:48 PM
FastKat's Avatar
Default Are any turbo cars NOT running oil coolers?
How important is an oil cooler on a turbo engine? Is anybody out there running a turbo car without an oil cooler?
I'm just trying to eliminate unnecessary parts and wanted to see if I could clip off the oil cooler as well. I am sending my pressurized engine oil off the oil filter to the turbos and wanted to see if I needed to put a T in to go to an oil cooler as well.
-Dave
Old 03-30-2007, 03:51 PM
Tiago's Avatar
I never had one until recently.
Old 03-30-2007, 04:06 PM
Juiced's Avatar
I am but i am doing it in conjuctiong with a remote filter mount and 1.5qt filter to carry as much oil as possible in the car.
I guess you could say i' paranoid of sucking the pan dry and not only blowing up a motor but a turbo aswell.
Old 03-30-2007, 04:16 PM
Pathological Modifier
Ryan K's Avatar
Unless the extra oil is in an accumulator, or in the oil pan, the is Zero protection in having a "larger oil filter". The oil filter is after the pump, if the oil pump looses suction, all of the hoses and filters in the world aren't going to keep that oil moving.
Ryan K.
Old 03-30-2007, 04:30 PM
otherwhitemeat's Avatar
I've never ran one,......but I got a single turbo and my buddy has twins, and he has to run one his oil temps get way up there.. funny thing is I've never even checked mine to see how hot it gets.
Old 03-30-2007, 04:36 PM
Juiced's Avatar
Ryan K.
but it keeps more oil draining down the motor
Old 03-30-2007, 04:51 PM
mdhmi's Avatar
I'm not running an extra oil cooler.
Old 03-30-2007, 04:58 PM
FastKat's Avatar
Thanks for the input guys, keep it coming. For the record I would have no oil cooler at all... it's not a matter of adding another or upgrading to a larger one.
Old 03-30-2007, 05:13 PM
FastKat's Avatar
Also, my primary concern is oil temperature, not pressure or capacity.
Old 03-30-2007, 05:53 PM
Ryan K's Avatar
nope, and if it does drain back to the engine, when the engine is off, it will cause the you to run even less oil in the pan. Other wise, the oil is just dead, oil is not going to "drain" into your bearings.
Ryan K.
Old 03-30-2007, 06:07 PM
bboyferal's Avatar
I never ran one for a year, but I recently decided to run one because several rows through the gears would drop the oil pressure considerably. It's being installed now along with the new motor, so I expect steadier oil pressures/temps... That's what I'm hoping.
Old 03-30-2007, 06:10 PM
anarchy99's Avatar
Never ran one, but I've been thinking about it lately.
Old 03-30-2007, 06:14 PM
LS1Tech Sponsor
Superman09's Avatar
whats an oil cooler cost, which ones are you running and how are you mounting them? Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 03-30-2007, 06:35 PM
FastKat's Avatar
Cool, I was hoping to not do an oil cooler but it seems like it might be smart to add one now. Damnit.
Old 03-30-2007, 10:49 PM
THE_SUPRA's Avatar
i know bunches of people who dont run one...
...then again you can buy a fluid cooler at advanced autoparts for less than $60. for an fi build thats a drop in the bucket.
Old 03-30-2007, 11:01 PM
fullthrottledan's Avatar
Im currently not running one, but its on the todo list. oil temps are in the 225 range with a coolant temp of 190 after a few gears down the road.
Old 03-31-2007, 12:20 AM
FastKat's Avatar
Cool, it seems like an oil cooler is needed to maintain a reasonable oil temperature if you are going to be beating on your car. The cost doesn't bother met at all, I was just looking to cut some weight, cut down on the clutter in the engine bay and free up some frontal surface area for my rad, condensor, heat exchanger, etc.
Old 03-31-2007, 03:12 AM
RooRnZ28's Avatar
i'm thinkin this is a good idea... so would it be beneficial to mount it in between the oil return or supply on an STS kit?
Old 03-31-2007, 04:54 AM
Adam98Z's Avatar
Return is where I am thinking about doing mine. Anybody who has one care to give a little info?
Old 03-31-2007, 09:26 AM
FastKat's Avatar
If I do it, I will use the stock feed and return. There's a flange on the oil pan directly above the oil filter that can be tapped (if it's not already tapped from the factory) for a pressurized oil feed line and a return line. I would use that line to feed both my oil cooler and my turbo. My turbo will gravity drain through my oil pan and the oil cooler can drain back through the spot above the oil pan
BTW, finished my oil pan 2 weeks ago... need to get some pics up!
-Dave
Quick Reply: Are any turbo cars NOT running oil coolers?
