More Turbo Pics!!!!
More Turbo Pics!!!!
These pics are of the 4in. inlet tube.All the cold pipes are done except for the inlets to the turbo's,no biggy.The oil line will be completed tommorow and the flanges came in today for the wastegates,so they will work on that as well.It is so close i can taste it.I almost hate to take it back apart to get it all coated.
What kinda car is this for? What are the specs of the turbo? Do you have any mods to your car? Where did you get the turbo? What are you coating with, where and how much? Did you keep all factory accessories? (Sorry- that's a lot of f'n qustions!)
Originally Posted by cablebandit
no idea on the cost? I thought you told me that you thought you could pay for it by pawning 2 of the wheels on the mobil home!!
I think you are gonna kill that tranny...I forget whats your car weigh? You are gonna be making an ASSLOAD of torque.
As far as the tranny you can go ahead and say i told you so,because it probably won't but it is rated to 700rwhp so we will find out.
you should try pushing the thing around the shop everyday!!! that poor tranny
turbo positioning
Originally Posted by MIGHTYMOUSE
have to admit, i wasnt real into this turbo positioning at first.. but i am steadily falling in like with your set up.. good job man.
turbo positioning
Originally Posted by Cam72aro
I am curious if this is going to raise iat's because of sucking hot air from the radiator? Would it matter if you are running an intercooler? I would like some input on the positioning of the turbos as I am about to start putting together my setup.
turbo inlet
Originally Posted by HUNTER02SS
Well the air is blowing thru the radiator,so the hot air will be behind the inlet of the turbo's.The turbo's will get the air first as it passes by the intercooler and then to the radiator.You would definatly want to run an intercooler especially with 20psi.Even on procharger kits with corvettes the air filter is placed in front of the radiator.If the inlet to the turbo's was behind the radiator then it would suck hotter air,but not in front of the radiator.Hope this helps.
So you have the inlet of the turbo pulling air from in front of the radiator? It just looks like the turbos will pull air from the radiator, or do you have inlet pipes that go in front of the radiator? It does help, thanks a bunch, Josh
