ProCharger idler pulley issues...AGAIN!
Old 04-02-2007, 10:11 AM
11 Second Truck Club
Superado's Avatar
Default ProCharger idler pulley issues...AGAIN!
Well, these have lasted longer than the previous ones, but none the less...are ready for changing again...
This will be my 4th set...
First time was basically the lower one (that sits behind the large ATI supplied aluminum bracket) being reduced to a "V" shape...
Second time was both upper and lower bearing failure, of which the upper had the snap ring break and pulley started walking back and forth on bushings...
Third time which are my current pullies...the lower, again, is wearing out quickly...upper not bad at all...
When I installed this set, which was over a year ago, I also changed my stock idler and tensioner assembly as well as using new ATI idler bushings, which seemed to cure the problem...until lately...
Anyone have any insight on why this one in particular gives me problems? I have read all the threads here and elsewhere...I know others have had similar issues, but is there still no good fix?
Old 04-02-2007, 12:02 PM
koji777's Avatar
The only issue I've ever had was wearing out the idler its' self. I went to the junk yard and found a steel one off a truck, problrm solved.
Old 04-02-2007, 01:22 PM
Superado's Avatar
if you mean the big stock idler...I replaced it last change...I don't know what's up with the little aluminum ProCharger idlers...especially the lower one...ATI says that they upgraded the bearings a year or so ago, but I don't know if its a bearing problem or not...
I believe I still have original upper one...I may just put in the lower location to keep from having to buy another right now...
Old 04-02-2007, 01:24 PM
Superado's Avatar
I don't believe they make an 8-rib upgrade for the truck P1SC...maybe that's the real problem...it being a 6-rib that is...
Old 04-02-2007, 09:39 PM
Superado's Avatar
ttt...
Old 04-03-2007, 03:05 PM
Superado's Avatar
ttt...no thoughts?
EPP, is there an 8-rib conversion for the truck set-ups?
Old 04-04-2007, 09:53 AM
Superado's Avatar
ttt...
Old 04-05-2007, 07:20 AM
BLNLS1/RX7's Avatar
You need to talk with Bob at Exotic Performance Plus.com. They wrote the book on Pro charger installs and are North Americas experts on the ATI Pro Charger issues.
Old 04-05-2007, 07:40 AM
EPP
EPP's Avatar
Thanks! We don't do that much with the truck installs. Anderick could tell you if ATI makes an eight rib kit, it is not listed in their guide. If they don't, I would think one could be adapted. Bob
Old 04-05-2007, 08:58 AM
Superado's Avatar
trust me...Bob was the first one I contacted...
Bob...who is Anderick?
Old 04-05-2007, 11:44 PM
Superado's Avatar
ttt...
Old 04-05-2007, 11:46 PM
andereck's Avatar
ttt...lol
PM replied to.
Old 04-05-2007, 11:58 PM
Superado's Avatar
speak of the and the appears...
thanks for the reply to my pm Mark...I'll be calling tomorrow...or today that is...
Old 04-06-2007, 12:00 AM
andereck's Avatar
We'll get you fixed up.
Old 04-06-2007, 12:17 PM
Superado's Avatar
and that they did...
thanks Mark...
awesome customer service!
thanks Bob @ EPP for the contact...
Old 04-06-2007, 01:34 PM
andereck's Avatar
Glad we could help, sorry for your troubles.
Old 04-11-2007, 02:48 PM
Superado's Avatar
Fed-Ex slip on door yesterday...signed it and the package was there today at lunch...
Thanks again Mark!
Kudos to ATI ProCharger...
Old 04-11-2007, 03:13 PM
Rickys S/C Z28's Avatar
wow thats great!!!
Old 04-11-2007, 06:24 PM
andereck's Avatar
Hope it squares you away, lef me know if you need anything.
Old 04-11-2007, 09:26 PM
Bad30th's Avatar
Way to go the extra mile to help a guy out ATI !
Rob (Bad30th)
Quick Reply: ProCharger idler pulley issues...AGAIN!
