fabricate your own 8-Rib Balancer
here's what I did:
put my stock Balancer on the Lathe and turned off the part thats between the 6 and the 4 Rib grooves then turned in 4 more grooves for the 8-Rib belt, this brings the SC (reverse rotation) closer to the Motor.
juiced: if you wanna go with a 12rib belt you have to turn off the 6rib section and bring it down to the same dia. of the 4rib section cause its not wide enough for 12ribs, that means you won't have a 6rib belt any more, you have to change all your accessories pulleys to 12rib, but I think you've had that on your mind before. I would gladly do it for you, problem is I'm located in Germany so shipping would be too expensive unless you have a buddy in Germany with an Army APO address.
Slowhawk: what should I do about the rubber damper? I think there's no need to do anything, I didn't go deeper than the original grooves so the rubber isn't damaged or anything
LS1Tech Sponsor
