View Poll Results: Which cam do you think?
LS6
6
75.00%
Custom
2
25.00%
Other (please specify below)
0
0%
Voters: 8. You may not vote on this poll
Mild DD turbo...questions.
Im building a mild turbo street car from a 99Z M6.(stock cubes and CR.) I want to run an STS kit (I know its not the best but I just like them) I have a set of LS6 heads and an LS6 intake. Im undceided about cams I would like to have a LS6 cam but I dont have one so I would have to buy one. Or should I just buy a custom grind for the app. I want a smooth idle (factory quality) with a bit more bit than a stock LS1 cam. any suggestions on anything would be great.
Originally Posted by deadmanTA
LS6 or a Lingerfelter gt2-3(small cam) have both had good results. Are building a low compression short block to use with those heads?
Just wondering cause I just sold my ls6's last year to by a set of 317's. I'm going to be useing the stock shortblock also just want to do it safely. My goal is 480-500 rwhp @ 8 psi though.
Good luck to you
Good luck to you
Good luck with your plan to stay on the "mild" side of forced induction . IMHO, If you can get a hold of LS6/ZO6 cam for a cheap price then go for it, but if the price is close to a new aftermarket one then just go with a custom spec. and you should have no problem attaining your goals on 8psi. BTW, you gotta love the sound of them STS, they sound so sweeeet!!!
power
Originally Posted by Armyman2445
I was planning on using stock short block. I dont want a boosted monster. I was wanting something around 420rwhp at about 5-7psi.
