OIL restrictor starting place.
Closed ex-Sponsor Account
What size restrictor is a good starting place. I got the racecar running today and notice a slight oil drip around the downpipe flange.
turbo is a T105 with a -4 line feeding it. OIL pressure is at 100psi. Drysump pump push the pressure, and T'd into the one of the pumps suction ports for oil drain.
Smoking out the down pipe is not bad, just seen the drip after shutting it down.
Ricky
Ricky
