Patriot Gold Valve Springs on a stock motor
hey guys, I'm slowly getting into the fi game with my daily driver. the plan is to go with a procharger. I'm trying to do some of the preparations for boosting the car in "weekend sized" steps so I can keep the car up and running as much as possible. I was wondering if it's ok for me to install and drive around with the patriot Gold valve spring kit on my stock motor before the procharger install & tune. Also, I've been told that I need to upgrade my springs, but didn't know how to determine the spring pressures needed and stuff for my application.
being stock internals, I am planning on trying for hp in the low 500s or a while. from what I've read, much more than that, and the motor will be pretty short lived. With a d1sc i think it will take 6-7psi ... p1sc will probably take 7-9psi. This isn't first hand experience as I'm new to fi, but just what I have read. Feel free to correct me if I'm wrong.
i just don't know how different spring pressures effect a stock motor. I mean, I would think it would cost a few hp to open valves that have a higher spring pressure. And it would seem plausable that an unusually high spring pressure could cause cam lobes to be eaten or something.
+1
Better pushrods would be required with upgraded springs.
Considering the overlap of time in doing the upgrades in stages,
you might be better off taking a day or two off work so you have
the time to do both mods (cam, springs & pushrods) at once.
I know I hate having to take apart stuff over and over again!
That way when you go FI, you won't have to tear into the motor.
Just my $.02
Just my $.02
yeah, I didn't mention it, but I was planning on doing pushrods, but honestly wasn't concidering a cam. The spring change is just a preventive measure to avoid valve float. I guess I could throw in TR's cheaTR or blower cam in there, but I wouldn't be getting a tune until the procharger install.
The Patriot valvesprings won't hurt your camshaft anymore than they would an aggressive camshaft. We use them on a lot of our installs, and I would use them in your combination. http://www.exoticperformanceplus.com....html?item=651 Bob
