Those who moved radiator up and verticle.... in here - Page 2 - LS1TECH
Thread Tools Search this Thread
Old 04-13-2007, 01:42 PM   #21
7 Second Club
ty_ty13's Avatar
Quote:
Originally Posted by PurEvl
stock radiator, the other thing is 4" intercooler
no no no.... i know what that monster fmic is..... in the pic i dont know if its deceiving me on not but it looks like you have to thin radiators... hmmm maybe not :shrug:
ty_ty13 is offline   Reply With Quote
Old 04-13-2007, 02:17 PM   #22
8 sec potential, 12 sec slip
ChevyChad's Avatar
It's probably the A/C condensor??
ChevyChad is offline   Reply With Quote
Old 04-13-2007, 02:26 PM   #23
PurEvl's Avatar
Quote:
maybe in that pic its there, its not anymore
PurEvl is offline   Reply With Quote
Old 04-13-2007, 02:37 PM   #24
code4's Avatar
here is a pic of mine. I did have to tig "L" brackets to bolt the rad onto my square tubing. I also had to tig a 1/8" bung for the vent line coming from the heads. On the bottom I used some hard rubber blocks that the radiator sits on. I had so much room that I was able to use a single 16" puller fan.
code4 is offline   Reply With Quote
Old 04-13-2007, 03:21 PM   #25
ChevyChad's Avatar
code4- what radiator is that?
Old 04-13-2007, 03:37 PM   #26
code4's Avatar
GRI-1-25241-X Radiator, Universal, Crossflow, Aluminum, 27.5 in. Wide, 15.5 in. High, 3.0 in. Thick, Each $189.95 1 $189.95
Same one that was mentioned earlier on this thread. The first one I recieved was warped badly. Summit sent another out without question & it was good. It has been cooling really good so far but it isn't hot here now.
The first puller fan got overheated from the turbo. I have a blanket on the turbo now & a heat shield, no probs since.
Old 04-13-2007, 05:32 PM   #27
LS1Tech Sponsor
Superman09's Avatar
Awesome set ups guys, so basically for this Griffen Rad to fit you need to cut out then support that runs across and either use the rad as a new support or run a thin 1x1 bar as a support and attach the rad to that? So does this radiator NEED to have the 1/8" bung tigged on or is it set to go as it comes? I have only heard of this from Code, thanks a lot guys!
Superman09 is offline   Reply With Quote
Old 04-14-2007, 12:13 PM   #28
ChevyChad's Avatar
I just realized that these guys with the relocated radiator don't have the windshield washer fluid tank. My WF tank is my meth reservoir, so I gotta keep it. Of coarse, all I need is to be able to get a 90 elbow on my procharger, so maybe I can get away with just moving the bottom of the radiator forward...
Old 04-14-2007, 12:23 PM   #29
LS1Tech Sponsor
Superman09's Avatar
yea, i already ditched my washer fluid and run a separate tank for the meth. Any more info out there?
Old 06-02-2007, 09:14 PM   #30
JasonWW's Avatar
Does that Griffin fit our stock sized hoses or do you have to do some fabing to get them to fit?
JasonWW is offline   Reply With Quote
Old 06-03-2007, 12:00 AM   #31
code4's Avatar
Quote:
The top hose fit very tight, the bottom was too big for the stock hose. I had to get a flex hose.
Old 06-03-2007, 06:34 PM   #32
JasonWW's Avatar
Cool, I just didn't want to assume the hoses fit and then be surprised.
Old 01-30-2008, 05:50 PM   #33
Sideways240sx's Avatar
Do you have to get a spot welded up for the vaum line to the head? what will happen if you dont? My radiator should be here friday.
Chris
Sideways240sx is offline   Reply With Quote
Old 01-30-2008, 06:45 PM   #34
88GT&69ss's Avatar
Custom Radiator
Check this radiator out! Pretty Sweet!
88GT&69ss is offline   Reply With Quote
Old 01-30-2008, 07:04 PM   #35
code4's Avatar
It's a steam vent for the coolant in your heads. I use it to purge the air out of the system before I fire up a new engine. I wouldn't delete it but I have no experience to say it is bad. If your car is a 98 it will have them on the front & back of the heads. On the newer setups the back holes are blocked & just the fronts are piped back into the radiator.
I welded in a 1/8" bung on my radiator to hook it up to. I have seen some guys pipe it into the top flat spot on the water pump.
Old 01-30-2008, 10:19 PM   #36
Cool, thanks for the info. Id just weld up a bung, but i cant weld aluminum.... I wish i had a tig. Ne ways, i can always figure out where i need it, and bring it to a shop to get the bung welded in.
And also my car is a 98.
Thanks, Chris
Old 01-31-2008, 06:32 AM   #37
Reject's Avatar
noticed that all of you with the Peter Griffens dont have A/C condensors. mine should be coming in tomorrow but was wondering howto go about that if one of you had already done it
Reject is offline   Reply With Quote
Old 01-31-2008, 09:13 AM   #38
Firechikn's Avatar
Quote:
The condenser still fits in the same spot. I put a couple of pieces of weather stripping between the radiator and cond., and between the cond. and new cross member. I made 2 brackets to sandwich the cond. and radiator to the cross member.
Firechikn is offline   Reply With Quote
Old 01-31-2008, 11:25 AM   #39
deadmanTA's Avatar
What are you guys doing about the sensor(low coolant?) below the cap; deleting it?
deadmanTA is offline   Reply With Quote
Old 02-01-2008, 01:44 PM   #40
Reject's Avatar
got my radiator in
(thanks fedex)
opened it up....and no griffin logo!!
are you all painting that on yalls or what? kinda sounds ricerish but i like the logo lol
Related Topics
Thread Thread Starter Forum Replies Last Post
What am I doing wrong? Hyper Chick Forced Induction 16 03-19-2016 04:04 PM
What trans cooler do I need? Josh98WS6 Automatic Transmission 8 02-01-2016 06:41 AM
5.3 Radiator swap Fans? SweetNova Conversions & Hybrids 11 12-03-2015 01:40 PM
Stock LS GTO Radiator in 71 Bird, help blswan Conversions & Hybrids 1 05-10-2015 08:06 PM
Cooling issues turned into other strange issues - help please KOTC Conversions & Hybrids 12 06-09-2011 12:11 PM
Tags
2005, 275, an, core, griffin, ls1, ls1tech, psi, radiator, s60, square, ss, support, tools, trailblazer, tubbind, vola
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
