Those who moved radiator up and verticle.... in here
Old 07-21-2015, 10:27 AM
  #541
Spectre86's Avatar
^ what fans are you running? Derale 16925
Old 07-21-2015, 03:55 PM
  #542
boss79z's Avatar
Yes. With racetronix wiring harness.
Old 07-21-2015, 04:50 PM
  #543
Spectre86's Avatar
racetronix makes a wiring harness for aftermarket fans? you have a part number or anything?
Old 07-21-2015, 07:27 PM
  #544
boss79z's Avatar
Check there website. They have a dual fan harness that is 100$ or so. You have to tap into 2 wires on the main harness near the hvac.
Old 07-21-2015, 09:34 PM
  #545
NemeSS's Avatar
I'm modding my stock shroud and reusing my stock fans reverse the wiring.
So they push.
Old 07-21-2015, 11:58 PM
  #546
Spectre86's Avatar
http://www.racetronix.biz/itemdesc.a...WH-004&eq=&Tp=
heres the harness in case anyone else didnt know about it
Old 07-23-2015, 02:09 PM
  #547
Rare96LT1Formula's Avatar
Old 07-29-2015, 01:50 PM
  #548
NemeSS's Avatar
SPAL or Derale fans????
Old 07-30-2015, 10:31 AM
  #549
I'm running Derale 16925's with the Painless 200/185 Fan Relay Wiring Kit.
Old 07-30-2015, 11:29 AM
  #550
bluecatfish's Avatar
I just ordered the XS model and gonna use a modified stock fan assembly. Should be simple enough
Old 07-30-2015, 11:39 AM
  #551
NemeSS's Avatar
Do u have installed pix?
Old 08-02-2015, 01:16 PM
  #552
What kind of modification did anyone Make to the lower radiator support? Or just add rubber isolators to the radiator and run it ??
Old 08-04-2015, 02:16 PM
  #553
smitty2919's Avatar
I had some 3/8" aluminum rod welded on the bottom and added rubber grommets to them. Then transferred the distance to some holes in the radiator support to have the rods slide into.
Old 08-09-2015, 10:13 AM
  #554
Tally TransAm's Avatar
finished mine this morning. got tired of having to pull the turbo setup to pull the radiator so i swapped in a 55241-XS
Old 08-09-2015, 11:12 AM
  #555
Not yet. Engine bay was mocked up, then everything gutted for paint.
Should have something here soon though.
Old 08-10-2015, 08:09 AM
  #556
MMorgan9812's Avatar
Looks great Tally!
Old 08-10-2015, 10:58 PM
  #557
lbm13186's Avatar
great job guys, ill be doing this soon enough
Old 08-25-2015, 07:48 AM
  #558
Patsy57's Avatar
Question for you guys, what size cubes are you running with the griffin radiator?
I have a 430lsx iron block motor which will have an f1r.
My concern is I run around 215 to 220 now. With the griffin radiator will I risk increasing my temps on my street car?
Old 09-04-2015, 12:09 PM
  #559
Patsy57's Avatar
Default Those who moved radiator up and verticle.... in here
Anyone have big cubes and use this radiator?
Old 10-08-2015, 10:59 PM
  #560
h_friesen's Avatar
dam this thread is ancient but still around!! lots of great pics and info! I owe yall a beer
Quick Reply: Those who moved radiator up and verticle.... in here
