Those who moved radiator up and verticle.... in here - Page 30 - LS1TECH
Thread Tools Search this Thread
Old 03-11-2017, 08:07 AM   #581
Chris'stransam's Avatar
Chris'stransam is offline   Reply With Quote
Old 03-11-2017, 10:34 AM   #582
has anyone tried using the griffin 55241-XLS3 radiator? seems like it would work and already has a steam fitting installed.
https://www.summitracing.com/parts/gri-1-55241-xls3
battmann is offline   Reply With Quote
Old 03-20-2017, 11:10 PM   #583
should be the same thing. scroll up to his link.. 5 or so comments up and that should clear up some questions.
Jake.Z is offline   Reply With Quote
Old 03-22-2017, 10:18 AM   #584
Heres mine these $7 brackets from summit work great
Turbo306Fox is online now   Reply With Quote
Old 03-22-2017, 04:04 PM   #585
Quote:
Originally Posted by Arsenal View Post
Here is my radiator setup. I had issues with it because of the location of my turbo. I needed my radiator pretty far forward. The Griffin radiator is a few inches to wide to fit between the head light mounts so I inverted it some like the stock one.
I made some L brackets and welded them to the frame and put rubber pads on them to support the bottom and I will have tabs weled to the top of the radiator that extend over the core support that I can bolt down. This is the most room you can get with the 27.5x15.5x3 radiator with out moving/removing the headlight mounts and completely cutting out the center support. I will have 2 pusher fans and im pretty sure this will interfere with the hood latch so I may have to get rid of the hood latch and put in hood pins.
what did you use to cut your frame??
Gotit4cheap16 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
What am I doing wrong? Hyper Chick Forced Induction 16 03-19-2016 04:04 PM
What trans cooler do I need? Josh98WS6 Automatic Transmission 8 02-01-2016 06:41 AM
5.3 Radiator swap Fans? SweetNova Conversions & Hybrids 11 12-03-2015 01:40 PM
Stock LS GTO Radiator in 71 Bird, help blswan Conversions & Hybrids 1 05-10-2015 08:06 PM
AFCO LS1 conversion radiators Racinjason424 Conversions & Hybrids 7 03-13-2009 01:39 AM
Tags
2005, 275, an, core, griffin, ls1, ls1tech, psi, radiator, s60, square, ss, support, tools, trailblazer, tubbind, vola
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
